There's also an option to "automatically remove once downloaded" but yes, for a millisecond of time, you'd have the file.
However, there's definitely a global trend about people chased for this kind of thing being seeders, long time, multiple files, essentially acting as distributors for others to obtain files.
Maybe it's the most low hanging fruit for legislators to go after, though.
Then again it gets mired down. What if you just share out the DVD that's sitting in your DVD player that you legally purchased?
"oops it was taken without my knowledge, those tricky pirates!111"
So can someone explain VPN and what you need to do to avoid being caught?
in short what it does is create a tunnel from your system to the VPN server then the VPN server connects to the internet.
so all the traffic from your system outbound is encrypted and has no identifying details.
and as there would be hundreds of users on the VPN server no-one knows who's traffic is whos.
great for secruity for public networks.
Some also have servers in multiple countries you can connect to so lets say you ahve a foxtel Go account but are in Germany, Foxtel block the traffic. but you can select a AU server and stream your V8Supercars. (this is a completely random scenario as I'm sure you can imagine)
but lets say you are being a little dodgy and want to download a tv show or a movie, (not that any-one here would)
so long as you pick a VPN provider that does not keep logs of traffic there is no-way to track who is downloading what data, even better select one of those end points i a foringe country that has no data laws.
there are a bunch of servers that do this for a nominal fee. Below is the one I use
https://www.ipvanish.com/why-vpn.php
https://www.ipvanish.com/privacy-policy.php#1
  • Like 2
It's still illegal. you cannot make a backup copy for personal use.
this was covered off during some PS2 lawsuits years ago.
Edit it was something about circumventing security in place by the movie studios.
Double Edit: they are not going after you for downloading..and they cannot at this point, it is the seeding/sharing that is illegal, same as selling a pirate DVD is illegal.
I wouldn't buy one that didn't already have the 6 speed box.
they are cheeeeeap and I need a train station car that is still kinda enjoyable
Inark bought one a while ago, not sure if he still has it
Got it cheap and had quite a bit done to it
Want one but with an off tap l28 in it
would be fun to go to:
https://www.facebook.com/events/754949701270445
just hope those who had top gear tickets got refunds...
still happening, its just called the james , jeremy and richard show.
all top gear branding dropped from the tours.
refund if you don;t want to go to the new version, or a ticket to the new one.
so yeah no-one screwed over. well unless you bought accom, flights etc
Just bought these for the skyline... $30 (new is $360 from Nengun)... in Typical Drift Sales fashion, no mention of the fact that they're missing the rod end spacers until I'm organising a time and location for pickup.
Ah well, should be able to source some that are suitable from Fulcrum or Hardrace etc.
Why is every fgt including a pic of their car in their wall post saying they might go? Who gives a shit if your evo 7 or Hyundai is there, what a fkin draw card
we do this on SAU events as well, once a few post it up shows others that no you don;t need a out and out race car or 100% perfect show car, any-one can attend.
bumps up interest as well.
think of it as a marketing thing.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
