Was at ferntree gully Nissan just before waiting for the parts guy on the phone... Someone putting rb26 in a gtt by the sounds of it ... Guy was explaing to the customer than the N1 model stood for nurgburgering.
Well done
Akshully is because Grp. N and N1 being the class the GT-R's competed in.
i was thinking that becuz N1 pulsar had no ties to the nur, so yeah, guess you're right.
messin round with clutch fans and fan shrouds like a true RWD noob. they seem to work pretty well though.
My friend just got approved for a business loan through NAB, what are the odds of you having anything to do with that or knowing the person Hamish?
having to do with - very slim
knowing banker/credit partner/analyst/associate involved in the lend (via phone/email) - reasonable
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
