It was supposed to be Alex's post quoted but this forum app does weird shit like that... Nfi where that post even came from, it's nothing I've read anywhere
yeah, I clicked the link to original thing and it just crashed my phone app... presumably due to the extreme retardation of the thread
Jono what is that ramen noodle contraption and how much do they cost? Might be easier than doing my shit on the stove
Interesting drain hole
lol'd hard at chicken strips, but there's an example of something looking shit and tasting good - I know that shit tasted good
wtf you on about? is there another thread im missing out on?
I know a guy who is in the market for a good 135i, srsly he is out test driving them now.
What's wrong with them?
Nothing it's perfect for a hairdresser or flamboyant tax evader Edited by alr33x
Supposedly they respond well to a little bit more boost, and BMW engines are good.
370rwkw in a 135i, with BMW everything else? 3L modern engine for dat response.
Why would you ever want a R33 in relation to it other than cost?
Srs question. Would strongly consider one if (when) I ever write my car off again.
Speaking from experience? :P messy breakup? that's what I'm worried about, bitches going cray cray and destroying your place if / when you want them to move out
That rule doesn't apply if they're paying you rent right..?
yes and no. certainly not messy which is good.
you can be smart about it but what freaked me out was that if someone is applying for welfare and meets all criteria except is living with a spouse/bf/gf/whatever, that person is then financially responsible for the other (if you earn enough, and by centrelinks standards it wouldnt be much). living together for 6 months that is.
Also, i had planned to go down the path of getting a legal documented created to state X was a tenant and paying rent, on the bond etc. not de facto by default. I never ended up following through with it though.
yeah mates mrs stays here like 4-5 nights a week too.. might have to have dat awkward convo and ask for contribution toward bills if shes gonna spend more than 50% a week here..
f*kn jump started in iracing and screwed my race up, then its annoying that you gotta wait another hour before any more official races lol
Edited by UNR33L
What's the Altona rental market like Alex? less stigma than Laverton...
good but you wont get much in altona for 400k unit at best and even then im not sure these days.
wouldnt worry about the stigma its not your problem lol
This happened in Project cars. Didn't know I had hold the brake pedal for go karts, it started rolling forward and race ended straight away. Stupid game didn't even say I got black flagged.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
