24 hours of lemons at wakefield on the 28-29th of october
seriously thinking about entering lmfao
car must be under $500, including mods, excluding safety gear and tyres
what the f**k can me and my mate buy that will hold up?
would anyone else like to form a team?
You can't get a $30,000 car to hold up, what makes you think you can do it with a $500 car
$500 gets you a lot of car when you don;t want to think about rego.
want some turbo charged Euro fun
http://www.carpoint.com.au/all-cars/private/details.aspx?R=SSE-AD-163018&Cr=4
maybe do it in some bogan style.
http://www.carpoint.com.au/all-cars/private/details.aspx?R=SSE-AD-3278450&Cr=1
but for yourself...I think look long and hard in NSW for a lancer with a evo body kit or a droid body kit with as much autobarn blight as your can find.....
then enjoy killing it.
(ie find a car some-one advertising as an ex autosalon show car..)
aye aye aye i made it to sydney and back and had to rescue a new focus and a 180sx on the way back lol
Yeah I was like that at my last job.. felt like I was getting dumber not stimulating my mind, I was starting to forget things in my personal life too.
I could seriously do 1-2 hours work a day and sit online the rest browsing stuff, every work day! (within the last 6 months)
New job don't have time to scratch my ass and 2 hour + longer days :\
Edited by UNR33L
Got into counter strike this week.
I enjoy the friendlier-smack talk, but fark me it's a sad world. Thousands of hours of play time, sitting on the same map, using the same weapons.... Worse than wow almost. Except it's stimulating (for a few hours)
Any of you liberal kunce know what the government's desired productivity % for various industries in Australia is?
ABS will have the raw figures, not sure about targets / projections. Why? Edited by HEKT1K
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
