Yeah well I don't even think he has mentioned it to her yet, because when I got home I got an SMS to discuss another day when shes not there, I'm like lets discuss in an open forum around the table with all parties? No reply.
Leaning more towards the Dezz attitude the longer I'm getting f**ked around
hahaha
I knew the guy wouldn't have told her anything...he's more scared of her than you at this stage. This is a bad thing and the perfect candidate for some testicular fortitude on your part.
Of course if you really wanna fk with Patrick's change management mindset then go behind his back and talk directly to his girlfriend, telling her how it is.
Yeah he wouldn't be happy going behind his back, would be impossible too as they spend every minute together
Day 3.
-Still no change
-Signing off
Day 4.
-Invite Dezz around for change management
Edited by UNR33L
  • Like 1
If there's one thing Patty will never forget it's a final inspection
Final inspection sounds like something an office slut does after lunch break to make sure there's no cum left on her face
https://www.my105.com/ListingDetails/id/15517/latest/1
quality photos and ad description. its the best looking AU falcon ever built (not that that says much). but was available on Gran Turismo 3 +$5000 sell price.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
