#daysofleighslife update:
Got given the 4 weeks notice and heads up they'll be moving in together somewhere else :)
Also, plot twist they've only been dating 3-4months
Edited by UNR33L
  • Like 1
Was always gonna happen brah - she was either gonna be there 5-6 days a week or they were gonna find their own place. Now you can start advertising for someone who isn't a drop kick.
Or enjoy the free space.
But with your complaints about mortgage lyf I'm guessing you'll prefer the former.
Nah actually prefer the latter, when he spoke to me I actually started getting excited and happy to live on my own - can turn that room into a study
There's no hard feelings, I wouldn't be surprised if a year down the track they break up and asks to move back in and by then I'd be loving it on my own too much heh
Edited by UNR33L
  • Like 1
3-4 months? ohh shit. danger will robinson.
less than 12 months is common for people 30 and older, but kinda makes sense if she was over all the f**king time. get them a watermelon as a house warming gift.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
