Not if the militant unions have anything to do with it :)
You can't really complain about no bonuses Leigh if you are going to bugger off at 5pm each day lol
haha nah i'm not complaining I don't expect any, at least pay rises are nice / paid company events etc.
and just because I bugger off at 5 doesn't mean I'm not in early and working my ass off :P my motivation to leave at 5 is I start getting f*kn hungry and wanna get home and cook some din din.
Edited by UNR33L
The value of your contribution should be based on the quality of your work not the time spent.
If you don't have time to have lunch away from your desk or finish on time, then the majority of time its either time management issues/faking it to look busy.
/my 2cents
Or unreasonable expectations from management
we have a winner
we are COMPLETELY understaffed then management or we get calls from angry clients as to whats going on, well we have a like 50 other cases we are working on so.. get in line
Edited by UNR33L
oh yeah forgot about party rock
I remember that time I came after work Christmas party in 2012.. I was a mess had to ask cabby to pull over on the eastern rofl, by the time I got home barely standing, Chris got booted out from memory too haha
Edited by UNR33L
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
