"Tourists heading for Greece are urged to take enough cash with them to last their entire stay as Athens announced banks would be closed Monday in a deepening financial crisis."
Maybe I should just paint a big target on my back while I'm at it..
what level of work you getting done? prices reasonable? what about (wait for it)... timeframe?
We are creating in his words a torque monster.
Prices are reasonable by the sounds of it. Timeframe ETA is about a month once they get the car, so using the workshop project multiplier, probably ~3 months. Barry isn't building the engine, just assembling, but there may be other issues I need to address such as clutch, diffs, gearbox etc. which would hold things up.
Excited :)
Lol, never gets old
Simultaneously the strangest and most normal thing I've ever seen in my life. It was a rational and legitimate proposal; why can't they accept 50 x 20 cent pieces as a cover charge, is it not legal tender? But, you just don't do it.
Not legal tender as it turns out lol
http://www.austlii.edu.au/au/legis/cth/consol_act/ca1965120/s16.html
  • Like 2
cool. low-down torque or never-ending-spool torque? im sensing stroker kit and mild cams (but strokers so pricey).
whos building engine then? or is that trade secret?
Is it the 750 that is the original or was that a special edition size?
750 = not AU market
Am I the only one around here happy with beers?
no, I LOOOOOVE beer. it's just that it's not worth talking about like scotch
  • Like 1
Torque everywhere torque
Real McCoy "Another Night" torque (I torque torque, I torque to you)
Engine already built; under wraps til it's done!
I got torque and my turbo is literally too small, so go get some 500KW low mounts
Also expect 1 year until its working
Unless you are just flat out buying an engine which is in stock which c'mon man does not ever seem to exist
We'll see - full story when it's put together :)
But yeah I may not be keeping my HKS GT-SS
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
