Perhaps if they weren't blocked at every turn it would be a different story
in fairness, their utes/trucks store their work-gear & tools for the job. They cant be parking 500m down the road & running back/forth for tools etc
Their car is their tool; the location of your car whilst working at your office wont impact you other than arriving/leaving times.
I'll agree on that to a point. But plenty of people use a car to fulfill their work obligations and they don't get special treatment
Nope.
Plenty of jobs have "carry stuff" requirements
Nope.
The utes/trucks may be used as a mobile workstation for welding/cutting/fabrication along with storage of tools.
Yes, people may use cars to fulfil their work obligations, but if it involves anything more than the above then they should also get a permit.
everoyne would expect to see an LS1 under there.
NOTA33 would be more entertaining. wish Tony could sport NOTGTR.
you should let the engine do all the work and get T51 just for the street cred and to have a chance of being photo'd when near a 34GTR
an electrician with a victorian licence cant do electrical work in WA or QLD without going through their hoops and licensing process.
I highly doubt foreign electricians to be granted work visas and to just magically get jobs (legally) when:
a) there is a work shortage with many in the electrical industry looking for work
b) immigration has tightened up like a ducks butt since 2011-2012
c) the companies with the power/cash to do 451 visas would most likely not risk hiring people with questionable skills and knowledge. (especially blue collar workers)
regarding unsafe cabling and installs in houses... home owners agree to it because they dont want to pay the extra for a proper job. someone beats a quote by a few thousand dollars and most people dont think twice about it.
Who do you think you are telling these experts what's what?
Q&A doing its usual close ups of audience hipsters with ironic beards and intense looks of concern on their faces
How much more is my mocha chai latte going to cost if this new tax comes in?
God these rainbow display pictures are annoying, yes I support gay marriage - no I'm not a sheep..
http://www.theatlantic.com/technology/archive/2015/06/were-all-those-rainbow-profile-photos-another-facebook-experiment/397088/
could be a potential facebook book experiment, monitoring how peoples views change based on their friends & how long the change lasts.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
