How do you drive around with broken suspension and not notice till you look under the car?
More to the point how do you have plural damaged suspension?
car has accident history? (or is this a new shell?)
"Greg"
This is a new shell.
Yes I meant the hankook RS3 sorry. If they are equiv, and $250 a tyre, well.. that's some coin saved.
re: My suspension
I hit a kerb, hard. Damaging a wheel, and bending a tie rod end.
Got that fixed and wheel repaired and new castor arms. all good.
Went under car, noticed the bracket I don't know the name of (what the front sway bar bolts to) has literally snapped off in half.
So that's nice. No idea when that happened.
I also asked TT to set my ride height at 350FR and 345R height. It felt floaty as FAAARK in the rear and I just blamed it on hicas till I actually measured the car and found the front is 330mm and the rear is 368mm.
So yeah....
How f**king hard did you hit it!? I went through a HUGE pothole a couple of weeks back. Took chunks out of both LH wheels and threw my alignment out. Gonna call the council and see what they'll do about it.
Working side (for reference):
Damaged side (for lulz):
Note: I did not notice this occur. It happened some time after traction tyres installed the castor arms and replaced inner tie rods.
Nah, ever since I got the rears put in, I noticed it felt really tail... 'rolly' as though the weight balance was 99% front, all the time. But I supplied the struts and springs to TT, as they came off the old car.
But stupid me didn't really think about the fact that while the fronts came off my old car, the rears struts were swapped, so the setting for rear height was lost when that happened. Did give them ride heights but as they (TT) figured they were swapping from one car to another they didn't need adjusting.
I had no idea the front sway was basically removed from the car via kinetic force.
If it all gets fixed up and it still feels weird then I dunno. Car didn't have that behaviour on the springs it initially came with, nor did my old car with the exact same setup.
but I'll probably blow my engine up again between now and when its time for another alignment
so this was the tyre that won street class at WTAC first 2 years.
then Yokohama sponsored and forced people on to their tyre.
so yeah it good.
That's The only prob with NT05's
The indicators coke up reeeeally fast. The trick is to not give a f**k and drive the shit out of them anyway. I used to rock mine well past the indicators
This is what I did.. although in wet you had to be real dam careful
I think I got 10,000km or maybe bit more out of them.. rears were shagged but fronts were still fine, usually I go down to the wire.. alignment Greg?
Edited by UNR33L
AD08 >>>>>>>>>>>>>>>> RS3
By far.
Why? (srs question)
Longevity?
The NT05's are just touching the indicators in the center now, on the sides there's maaarginally more, but barely enough to catch a fingernail on.
Where else to go for alignment duties? TT always been nice to me, but heard a few things now...
i havent really tried many reputable workshops in the south/east, but i still happily do the drive to Thomastown for Centreline.
Yeah i got an easy 10k from the fronts for daily duties and a few deca's. Probably would have got to 15 but I usually put them in the rears and fried them.
I disagree about the wet though. A car that needs NT05's is going to f**k you in the ass in the wet no matter what
That's a good point, when road is just wet its true it's more so when it' soaked with a few mm of sitting water even shitty tyres with channels to get rid of the water makes me feel a little better instead of a flat bald tyre aquaplaning
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
