naw mang that was my roommate lol (3? 4? months lel)
still, we only been together for a year, so valid point
A year is all relative .. Been together a year at 18 is nothing but a year at 30 is totally different I think
Agreed ppl are much less picky the older they get, more likely to stay with that person for longer than a year
Not sure about picky, but people seem more honest about what they want and 'get to the point'
Yeah the whole get to the point and honesty thing is also a part of that adult mindset responsible for them being less picky.
Correlation with age and people finding a long term partner - exists because of nature and also that societal push/expectation that they should settle down: "You need to find yourself a gf", "I need to get myself a girlfriend", "I want to have a baby" blah blah. Adult hormones kick in, women want children, men want company and not just sex because they might be past their sexual peak or have had little success with sexing lots of women. People get more desperate to achieve this, impatient even, and will settle for just a good person; willing to put up with more shit and acknowledge/accept some faults in everyone because desperate/impatient and realise their chances of finding that idealistic perfect partner / Mr and Mrs right that they were looking for when they were younger may not exist; "This is as good as it gets." Then the people they do find end up becoming their perfect partner...or not...if they break up!
People then return to a bit of pickiness post family or divorced cause they've been and done the settle down thing. It's hilarious the reasons people break up or end dating for when a middle aged divorcee; very similar to the shitty reasons people end things when young.
if you own an ex-F1 car... m ost likely you have access to a race truck/personal pit crew.
I'm not asking cos I'm wondering IF it will be expensive... i'm just curious as to just HOW expensive
Correlation with age and people finding a long term partner - exists because of nature and also that societal push/expectation that they should settle down: "You need to find yourself a gf", "I need to get myself a girlfriend", "I want to have a baby" blah blah. Adult hormones kick in, women want children, men want company and not just sex because they might be past their sexual peak or have had little success with sexing lots of women. People get more desperate to achieve this, impatient even, and will settle for just a good person; willing to put up with more shit and acknowledge/accept some faults in everyone because desperate/impatient and realise their chances of finding that idealistic perfect partner / Mr and Mrs right that they were looking for when they were younger may not exist; "This is as good as it gets." Then the people they do find end up becoming their perfect partner...or not...if they break up!.
I'm pretty much the exact opposite to everything you just wrote
  • Like 1
If you're settling for a good partner, rather than someone who is a fantastic partner, and is the right person for you then you're in the wrong relationship and sucks to be you.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
