full on....
I stopped washing my cars sooo long ago...
the skyline paint was f**ked when i sold it because I had not washed it from a 40c DECA and it had sunscreen all over it that I never cleaned off :/
the evo gets parked under a tree, so it really only gets washed when god does it (rain)
so. meteor shower tonight, 22nd april. true or false?
technically tmr night?
I did some hunting into this a week or so ago. I cant find any information regarding viewing from even the Southern Hemisphere let alone Australia. I am yet to look at proper aus-astrology websites but cloud cover today/tomorrow will ruin anything anyway. Had a keen eye over the cloud-radar last couple of days because been planning to hit Mt Donna Buang for some star photography (not me, a friend. I just enjoy the drive).
Ford forum sponsor has special $2000 for:
FG 6 Piston front kit @ $2000
Brembo 355mm slotted rotors
Brembo 6 piston caliper
Brembo brake pads
Goodridge braided lines
Custom alloy brackets
Tempting! Perhaps then I might do some trackdays..
Thoughts about Brembo rotors? how to they compare to DBA?
Serious?!
Brembo Rotors = Win!
Serious?!
haha yeah alright if i decide to get them I will go for the whole brembo kit.. but i wanted a dirt bike then these came up on special :(
brakes are for pussies. real men just use more accelerator
+1, Although sometimes I get fade after a few 200km/h runs back down to 80km/h on a private track
Still need them eventually anyway if I'm getting intercooler/E85 down the track.. would be an animal to pull up!
FYP Brah....
RDA is the way to go... Brembo is crap, stick with RDA's... proven track performance.
the RDA's in my 33 had proven crack performance
lol
Edited by UNR33L
For like $2000 to have massive stopping power is totally worth it, I'd say.
Guest
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
