this crazy being proportional to fun in bed...
I've been in a relationship with one who was damaged/paranoid crazy and one who was vindictive/aggressive crazy and neither were noteworthy. Not sure if willing to knowlingly test that theory hmmmm
5 months
I knew there was a hidden reason behind me somehow getting a girl who was 2-3 higher than me on the scale :rolleyes:
Artz, Tony... INAPPROPRIATE!!!! but yes, very.
She was just using you for sex
You were just a piece of meat Simon
cant find my the Rays key to my lock nuts... bit hard to take the engine out :/
need longer wheelnuts too... maybe some nismo 50mm ones
http://www.nengun.com/nismo/wheel-nut-set
If you need it I have a master key for rays locknuts...
Decided I'm gonna make an omelette for lunch.
Any secret tips, Mr Chef?
make it good
5 months
You were her field play. Breaks up with ex; tries to move on / distract herself from ex and/or make him jealous at the same time.
And lose that 2-3 points beta mentality crap!
Then there's only one answer - you're the crazy in this case.
Simon brah
That shit is whack and I knew where if was heading from the first line. I wouldn't have even replied to it; breaking up over email...
That last line is a kicker and will provide me with sufficient lulz and/or jimmy rustling for the day.
Consider it a bullet dodged early on, my man.
How long we're you with her for?
EDIT: almost forgot to ask, was she any good in bed? I would expect at least an R = 0.8 correlation for dat dere cray cray.
Diiiis
Going to leave it at gate pressure for now.
Will go crazy on it once built, don't want any chance of block windows, ain't nobody got time for dat.
I don't intend on using e85 on it at this stage, I only want ~300kw from it.
Haha... I'd be on e85 just to get ~300kW :P.
Jungle juice providing dat powah.
I'd like to blame Alvin here; the food at Chiba must be reputedly bad to induce that sort of reaction from the mere suggestion of going there.
This was one of my first thoughts... the logical conclusion.
make it good
Rest assured it was great.
But back on topic, yes, wtfux I see initial post updated with her email response. Wut. [insert text/example about bitches be loco]
Guest
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
