33Rs are easily the best value. Only a few more grand than the previous model and half the price of shitty examples of the next model. Looked at 32s and 34s, thinking no other cars really excite me these days or offer the same kind of value; nearly bought that silver v spec 32 in glaze's thread. Never used to find 33Rs attractive, but they've grown on me over last few months of scoping for sale section. 33 interior > 32
do an RB25 conversion
from a stagea
it will just bolt right in, cost half as much as a 26 and give the same result (basically)
and you can tell all the fanbois that you spent extra cash as you prefer 25's
Just pretend it was all custom... shit is totally worth it for the lulz
  • Like 3
from a stagea
Chuck 26 cam covers while you're at it and run single to fool peoples.
from a stagea
Lol
In saying that i think receipts for my engine rebuild cost about $5.5K. And thats supporting about 700-800hp at the engine
Guest
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
