Bachelor of IT (Computer Science / Software Development)
Meh.... doesn't actually give you any experience in the industry though
indeed when I moved out of my first role here, entry level telephone tech support over half the applicants had degrees and some had PHD.
with no industry experience no-one was interested.
those that worked on the side doing helpdesk or in PC stores, now they were snapped up instantly.
Cheers Paul, had a look at them and not really a fan of it. Looks.... weird LOL
Have had positive experiences with the E-Boost 1 in the past and keen to get the E-Boost 2. Loved all the features from the original!
can get 10$ cheaper
http://www.sau.com.au/forums/topic/406502-genuine-turbosmart-eboost-street-eboost2-now-on-sale/?hl=%2Beboost#entry7375923
or cheaper again 619:
http://peconline.com.au/performance/category/boost-controller/#product-listing
disclaimer never used these guys b4 but using paypal so should be fairly safe.
edit: have a store front in melb, so makes it easier yet again if you not sure about trusting them.
  • Like 1
have a Greddy Profec II spec-B or whatever. hides in the centreconsole so you never look at it anyway.
speaking of which i really need to sell my BEE*R rev limiter...
they sell sooo fast
had one that came in a package with a bunch of other stuff, was sold in minutes.
that said now nistune does launch control, might be harder to sell.
Guest
    • Omg Brake pedal removal.. FML!!
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 💪🏼 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
