http://en.wikipedia.org/wiki/Akio_Kashiwagi
"Kashiwagi owned a home and office in Tokyo, out of which he ran the Kashiwagi Shoji Company. He stated that he was the sole principal of his real estate and investment business. He claimed an income of a hundred million dollars a year, and a billion dollars in assets. His finances were so secretive that a credit review for casino officials declared his profession only as 'business'."
"Kashiwagi regularly played baccarat for large sums, betting 100,000 or 200,000 dollars a hand, for hours at a time. He later got into a legal wrangle with Donald Trump's Atlantic City casino in 1990 over a deal in which Kashiwagi was to bet $12 million. Kashiwagi left the casino with two million dollars in chips, having lost ten million. He claimed the casino had failed to hold up its end of the deal."
"On January 3, 1992, Kashiwagi was killed, stabbed as many as 150 times with a samurai sword. His body was discovered in his home in Japan near Mount Fuji.[1] At the time of his death, Akio still had casino debts in the millions of dollars."
I'm guessing he wasn't the one who bought the apartment
Those are small figures based on what my mate was telling me... Obviously no idea if their true, but the numbers are obscene
this was mid-late 80's bro. and well before china had a million millionaires.
scarface wishes he had that portfolio
back then... japan was the old china (as far as my understanding...). and japanese only wanted Gold Coast and Sunshine coast property, lol.
China has probably about 200 multi millionaires
Guest
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
