Im told cardio is shit for weight loss and that I'll lose faster by lifting..
Ps I have a Second interview at Mercedes financial team. I'm hoping I get it
Crock of shit...lifting promotes a bigger intake of food to fuel muscle growth...it's almost counter productive to your goals of losing weight. Run fast and eat well, that's all you need to know.
How's the new job? Did u go with Nissan? (sorry if I'm thinking of someone else) lol
ahah nah mate ended up going with honda.. the job seemed more to my liking, its more a full detailing job, also preparing new cars for customers, taking off plastics, fueling, picking up customers if need be etcetc
and the nissan job which i applied for detailing was pretty much just washing cars so lol decided not to take that one.
though the nissan one would of made it much easier to order some parts im guessing :P
but yeah im enjoying it, its very physical and is keeping me very busy!
Spotted you twice in 3 days...
It looks so nice!
ahah where did you see me grant?!
i drive home for lunch everyday since works only 5-10 mins away - so im saving some cash that way, but prob losing it in boosting the gtr home lol :P
yeah i clay'd the car for maybe 5 days and just need to do a nice cut and polish on it and clean up some brake dust on front wheels and will look better again!
after i get new coils ill take you for a spin!
Tuesday, at wetherby rd into King st and today on blackburn rd both around 4.30pm, so you must be on way home.
Tried to wave you on Tuesday, I am currently driving around in mums BMW 535i now.
It's going to be painful 2 and half months...
Guest
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
