Are the tomei REAL 3 inch dumps? That´s the only one I could find where you can see the custom dump pipes...but it was before the GTX came in.
Series 1 are 72 mm internally.
Series 2 are 68 mm internally.
I have to measure again, I think I used 80mm pipes and bends, so 76mm inside diameter for each turbo until the cat converter, then 88.9x2mm to the back...as the cat is the biggest restriction anyways.
That´s why I used two catalic converters on the GTR, and after the middle box there´s a 114.3x2mm pipe towards backbox + end, as this was the biggest possible diameter between rear axle and LSD :D
Edited by AndyStuttgart
I can prove otherwise on my own car. do a bit of clearancing with a die grinder, wrap the dump pipe, done.
Give it 18months and then see.
I killed 2 silicone joiners on a low mount setup /w heat shielding over the course of 2 years simply due to radiant heat.
Sean has certainly done it right the first time. I'd never silicone in that area again.
  • 3 months later...
Spat a bolt out of the turbine housing on the rear turbo, so exhaust leak...
My fault as I only used bolts and washers to attatch the rear housings, as they don't come with attachment hardware.
Permanent fix this time with the correct half retainers from some other turbo's in the shed.
Next time I go on a dyno, I'll put up a sheet.
Yeah do everything myself at home including engine builds lol....
Yep twins are fun, 6th time ever on GTR's now....probably 4-5 times with engine in the car, stubby ratchet ringies are your friend :D
here are some pics of a local newcastle engine builder & his latest project.
gtx snails with a few other goodies...take note of the intake plenum & flux capacitor. absolutely awesome fabrication work!
I can see one of the goodies from here... that sneaky Newcastle fella!
Had a play with a nice GTR with a set of the GTX's (modified -5 front covers) last week we ran out of spark (see dip) @ 460rwkw on E85 @ around 23psi definitely good turbo s even with the hybrid front cover..
Had a play with a nice GTR with a set of the GTX's (modified -5 front covers) last week we ran out of spark @ 460rwkw on E85 @ around 24psi definitely good turbo s even with the hybrid front cover..
What size wheels? 60, 63 or 67's?
Yeah what size? And what sort of response?
Edit: see the graph now
Edited by jangles
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
