If you share that 3.5" exhaust between the 2 GTX63s it is only 1.75" diameter exhaust for each 440hp turbo!
That's a huge ask from 1.75"
That Z32 shows its doable just open up the inlet and exhaust more and if it doesn't work then I'll right them off.
But for now there my 600 wheel horsepower turbo of choice
Edited by mr skidz
Front housing machining has been done on my GTX2860's, picked them up from MTQ this morning.
I'm about to do a multi week roadtrip down to Victoria, so they won't be going in for a little while. I'm hoping maybe January. I need to sort out a few things first, like fuel system and exhaust.No point putting them in if something else is holding them back.
  • Like 3
Gorgeous wheels pete, how much power are you aiming for?
E85?
Just spin them as hard as you can too..
I've been held up by my machinist he hasn't given me my head back yet so I'm able to delay my turbo choice.
Edited by mr skidz
As above, they're -5 housings so .64 ar I believe.
And yes, e85 of course!
Power wise, that's to be determined by my work outlook. Worst case I suppose would be standard engine with arp headstuds. Id still throw a heap of boost in but may be limited
  • Like 1
Nothing wrong with the standard bottom end, as you said just wack a set of ARP2000 studs and also maybe some drop in cams and away you go!
  • Like 1
One for you pete, GTX2860's custom high mounts on a std 2.6L pulled 373 rwkw on only 17psi using stock ported comp covers and says .73 turbine housings??
Definitely different
https://instagram.com/p/77nQx7FHfn/
Edited by mr skidz
Does any body know if a -9 rear housing will work with the gtx cartridge? Wheels are the same diameter just a different trim, 76 vs 62. As i have -9's now was wondering if i just got the machining done and swaped out the cartridges.
edit: Looks like the -9 rear exducer is 34mm while the -5 is 41mm so I'm guessing no, only other question is will a gtx2860 front compressor fit on a 2859r cartridge?
Edited by fomby639
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
