  • 2 months later...
What is the highest recorded "realistic" figure being pushed on RB using -5/2530/-10/RS - 0.64 hot sides?
This is my car on -5's, E85, built 2.6 with all supporting mods.
Going 2863's as Garrett sells them with my old rear housings in the new year, hope to see improvement everywhere.
Edited by Wesley James R32GTR
Are people not getting harassed by police after they see a big single slapped on the side of the engine?
The way I see it I'd rather have as much as possible and hidden away rather then eek out an extra 200~300hp crack the gate once get pulled over and defected then put it back to stock to pass it all.
Been there before its a massive head f**k!
Or are the popo a little more relaxed these days, just curious?
every 20min something with a gate is screaming past my house :)
Edited by mr skidz
No need for homo gate rubbish. Plumb it back :yes:
Don't be jelly, you love gate deep down inside like how you love big singles 7 years ago and it took you till now to come out of the closet :)
  • Like 1
I don't like the tone of screamer pipes, much prefer the tone and sound of it coming out of an exhaust.
speaking of gates, I should probably get some 15psi garrett actuators for my turbos instead of using the 10psi tomei ones shouldn't i?...
rule of thumb (for myself that is) 75% or so of your targeted max. desired boost.. so say you want to run 2 bar, get 1.5 bar actuators or so.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
