i find your attitude towards ethanol surprising roy... for someone that loves to tinker as much as you do and tries to run his motor on the ragged edge, i would have thought that if there was an obviously better fuel choice, you would have been all over it
i didn't find it was too bad with the GT-T - on the cruise, so freeway driving etc, my consumption only varied by about 10% to 98, and about 25% for urban duties. If you do lots of freeway km's, it's quite a cheap (and powerful) fuel.
it is like how he is obsessed with rb20s for some reason, makes no sense.
LOL, i have the injectors that will give my fuel system enough head room. My problem is the amount of kms my car does as a street car makes it pretty hard to go E85. So the only real option is flexi fuel and cant justify the spend on electronics. So when I start doing more street kms in the Sierra the R32 may find its way on to E85 as it wont be doing so many work kms to Geelong, Yarrawonga etc etc
So until then I will just sit back and hang shit on people who are fortunate enough or dedicated enough to be running corn feed :thumbsup:
LOL, its all a bit of fun but its hard to justify replacing a $600 engine that has done 60,000kms and still makes ~260rwkws. If I can get an eflex setup going it would be able to catch up a little in the power game as anything under 300 these days is cannon fodder. But seems the eflex arrangement is about 3k. :( I am close to having an eflex setup for free which if it works will be ACE :)
What's the price comparison between 98ULP and E85? have never seen it for sale up here in brisvegas
i pay about 100-110c a litre here in SA. haven't noticed a huge increase in consumption on the track, even with a bigger turbo and 50% more power.
That's pretty good considering I just filled up on BP98 @ $1.61/L
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
