Top bearing. Ignore the scratches on that photo. It's where we pused the piston and rod out.
Bottom bearing.
15 months (10,000 kms approx) of running E85 using 300V 15W-50 oil. Engine was alive for 32,000 kms and used the same oil the whole time. 8000 RPM generally was the shift point but it did see 9000 a few times. They don't look half bad considering the oil pump died and the head is as useless as tits on a bull.
Bottom bearing.
and didnt burn a drop of oil its entire life :worship:
I'd say that would have to do with the super tight clearances and the run in :thumbsup:. Spoke to Mik about the run in and it was long hard pulls in 3rd and 4th up to 6500 within 10 kms of being screwed together. He did that every night for a few weeks on Old Pac.
yeah for sure, was obviously bolted together nicely... stupid pumps :domokun:
Bottom bearing.
What happened to the head to make it useless ?
Oil pump smashed. Ex cam welded itself to a few cam caps, belt jumped a few teeth and every ex valve got a little frisky with pistons (bent every valve and scored the chambers) . Intake cam is ratto.
Fark...talk about a catastophic chain of events caused by one shit part ,hope it didnt damage the RRR block .
maybe the 15w50 was the key then. I know Midori built my 26 on 10w40 300V and i would think that is a standard weight/viscocity for a street R, and if there are indeed issues of thinning etc, perhaps the 15w50 covers that off and it's ok to run the 300V.
Be interesting to see what Motul themselves think after sending them this info.
I would still like to have a sample taken and sent away although after it went bang I wasn't really in the mood! I don't think the amount of metal (or should I say bits of oil pump gear) would give a good and accurate analysis. A susmmary saying "Too much oil pump shavings in oil. May need to check engine" wont tell us much pinch.gif
Maybe chemically the Ester base oil's with alcohol fuels dont mix but changed enough it doesn't become an issue. The longest mine ever went without an oil change was 2000 kms. Track days and dyno tuning it always got new oil.
And you said it wasn't using oil! Man, that's "using" oil. ;)
Does that mean an ester based oil is fine to use with an alcohol based fuel? (getting back on topic)
it's actually more time that's important than k's. if you take your car for a thrash, have a bunch of contamination sitting in the oil, it has time to react with the ester even if it's not being driven. obviously the more k's and the more blow by = more contamination, so it's a mixture of a few elements really. but yeh, from what penrite say, they believe that you will generally need to change oil for other reasons before the ester begins to break down, so with regular changes it is ok. i'm gonna aim to change every few months which will be about 4-6 track days, so should be fine.
with how you drive? what kinda oil temps are you seeing at the track?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
