Picked up the car today, I can't believe how good the car feels with 300+ kw, it's now feeling like a skyline should :D am still on low boost and up to E49 fuel, so 325rwkw roughly I think... NO traction in first few gears but it's SO nice to drive.... Boys have done an amazing job!!
Can't wait to try high boost 4 the lolz :D
Will post a dyno sheet later... For now I'll be enjoying learning the new found power...
Massive smiles though :yes:
you want lolz.. drive it in the wet..... :yes:
then when your doing 100 on the freeway just squeeze the throttle a little ;)
Yeah I'm a bit worried about that... It comes onto boost so strong, it's just gate and wheelspin if you plant it... :)
seriously............who cares :D
but most of the time on the street your off boost anyway so dont really use alot more fuel than normal...
get into it hard and it will start using juice pretty quick of course
this, it's not for economy!haha
Just a quick question, what sort of fuel consumption are you guys getting with 300+ atw?
How do you intend to drive? Economicaly or not?
With 370rwkw I could get 450km/s to a tank in my GTS-R (and the tanker GTR i managed over 600kms on a fwy with 330rwkw).
Also managed 200km/s to a tank regularly in the GTS-R and GTR.
So as usual - it's all in your right foot, and the tune. Either way if you are worried about economy, buy a Prius
hahaha fuel economy questions make me lol :)
I rented an SRT-10 Dodge Viper in Vegas this year and chewed through 60L of gas and only did 85miles :D Im guessing that had NOTHING to do with my driving though? hehehe.
Mine is 280-300rwkw depending on the dyno, and i still get 550 a tank if im relatively nice to it. On a flat piece of highway i have got as good as 14km/L. I thought that was absolutely fantastic! But then the flat plains run out and it all went to shit in the twisty hilly stuff for the rest of the country. AFR's in the 14.3 - 14.7 on cruise @ 100km/h, and 11.6 - 11.8 full noise. (98octane)
Hehe yeah i know. Its just entertaining for me for some reason. Small things..
I asked my dads friend what the economy was like in his Bentley Continental last year for shits, and he turned around and said "Son, i didnt spend $300K on a car to worry about how much it costs to fill the tank" LOL!
How can you people get such good fuel economy with 300ish rwkw? My daily driver R34 200rwkw ALWAYS gets 19-20L/100kms, it is seriously REALLY f*ked. My right foot is not too bad, just the ocassional squirt to 5-7k rpms in 1st, 2nd and 3rd lasting less than 10 seconds.
hahaha that's awesome
I dont see how the power level really matters. Its only the amount of time you spend with it heavily loaded that matters. With a good economy tune for normal driving, and i rate my economy tune very highly, it should be more economical than it was when it rolled out the factory door :) Or dam close to it!
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
