Yep, me too. Only motul fluid i use is their RBF600 Brake fluid. Have had no issues with that whatsoever.
Their oils on the other hand, cost me a couple of lifters in my 25, and also caused issues in my S14. Changed oils (And replaced lifters) and all was fine.
My tuner used to stock motul, and had quite a few problems, and now he himself stocks and uses nulon. He also Carries ULX oils.
Was Motul Turbolight 4100 10w40 in my sr, and motel 300v chrono 10w40 in my 33/rb25.
Switched to penrite in the s14 and put in new lifters and changed to nulon in the 33 and all was good.
I thought there may have been an underlying issue with the lifters in the 33, but the problem started from that oil change. Tuner said he had had the same issues with a couple of 33's he tunes/looks after.
In my case it was turbolight but I don't think it's fair to say that was what spun the bearing. It was a 200,000+ km motor running 300rwkw and was a track car of some sort in JP.
However the as soon as I changed from shockproof to motul for the gearbox it became a bag of dicks overnight and lost 5th. All gears started to crunch a little and generally felt less tight.
The diff always worked but a few runs on the skidpan was enough to kill the diff fluid. It would make a lit of weird ticking noises after a few runs and would never return until a fluid change
It's known shockproof destroys boxes, get a perfectly healthy box, add on shock proof and then watch the box deteriorate.
It's only good for boxes woth worn down synchros, if it's a healthy box steer clear of it.
Never had issues with shockproof, but have not used it in freshly rebuilt boxes. When I put my OS gears in I won't be using it.
Isn't it funny how views over 10 years change.
Ugggh I run Motul Htech 100 in my 33... and I've got lifter tick by the sounds of it.I used to run Penrite racing 10 10ths (10w/40) then JustJap recommended the Motul..
Looks like I'll be changing oils sooner rather than later.
The precise symptoms I was talking about. My 33, and a couple of other customers had the same issues after using motul. Not sure why.
Penrite Racing 10, 10w40, just changed mine at roughly 7000km while car is off the road and has been going well in the 33 gtr, no problems experienced. Other people use HPR 10w50 with the added zinc and rate it well also for an engine that has done a fair amount of km's.
Refreshed a gearbox from a 33 gtr recently also. Cost of new bearings, synchros is fairly cheap from Japan, just take a few weeks to get all the parts. Longer if have to order more parts during the refresh. If you pay someone to do it and provide all the parts it's not that much in labour. Compared to having a crunching gearbox that is crap to drive I know what I'd take.
Once refreshed of course the gearbox feels brand new basically, worth the money. If you are not hard on boxes, the refresh will likely last for a long time.
Never used Redline oils in the gearbox and probably never will.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
