Andrew from AM Performance ran his car on the same dyno at Jason, and made 308rwkw, then went down the road to the Willall mainline and made 249rwkw. just to give you an idea of the difference
at the end of the day its for tuning, not for bragging
tis annoying how some dynapack owners dont calibrate it properly though.
trent runs the same dyno and has his reading within a few kw of a dd for when he does printouts.
makes a lot more sense for comparisons
How is reading DD like dynos "properly" calibrated?
What he means is that most dynapack dynos read significantly higher than a DD dyno in the norm and trents one pretty much is spot on with other DD ones which arent happy so it makes for a better comparison with other peoples results.
There are 4 calibrations for different regions (like usa which use old std) and test procedures:
SAE
DIN
and two others i cant think off.. lol (as i never change it)
some of the operators in sa seem to always run theirs in the old standard which inflates power... have bought this up a few times with them as they give the dyno a bad name even though its actually far more accurate.... hell i could have got a 4wd roller for the price of my new 2wd dynapack...
on top of every dyno sheet from dynapack is the correction type used, if it isnt in SAE J1349 (2004) ask it to be changed. Also like any dyno make sure the Air intake temp probe is set to ambient and is reading real ambient temperature
Almost a direct overlay of my T67 set up on the same type on dyno with the same correction... Actually uncanny!
Which begs the question, how much boost?
Yellow run was 17.10psi
Green run was 18.36psi
There are 4-5 calibrations for different regions (like usa which use old std) and test procedures:
SAE J1349 (2004)
SAE
DIN
SAE
DIN
Is there SAE J1349 a separate setting to SAE? I always have used SAE... and "inflates power" is surely a relative term, regardless. So long as all details are considered it is what it is, I'd call it more "inflated" where people reduce smoothing in the hope spikes will boost the #s.
Unopened rb25
Gt3076. 82 IW
Caltex eflex
310rwkw 16psi
320rwkw 18psi
Leak in cooler piping/plenum that needs to be fixed then its back for a tune as it wont hold more than 16 psi and sounds like I got a midget under the bonnet blowing a trumpet lol
Damn that lil midget bastard gets around! he was under my bonnet too lol
Unopened rb25
Gt3076. 82 IW
Caltex eflex
310rwkw 16psi
320rwkw 18psi
  • 1 month later...
and the funny thing? both are mainlines.
use this formula:
mods: PowerFC, GT3037 Garret, 0.6 cpm Cover, 0.63 rear housing, 18psi, Nismo 555s, 3inch turbo back exhaust, 600x300x75mm intercooler, Split Fires, NGK BKR7E plugs, Water Methanol injection, 275ml min nozzle.
fuel: Shell 98
power: 320rwkw, 720nm Torque @ 3200rpm
oil: Shell Helix 5w40 fully synthetic
useage: Every day
lifespan: Lasted 4 years, until I decided to upgrade to RB2530. Engine was still 100% compression wise when sold. 165psi accross all 6 cylinders.
failure: none
comments: Was an awesome car to drive. I did all the tuning myself.
  • 1 month later...
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
