Hey all,
I've done a search and have found plenty of information on the V44, though not much on the G4. I suspect there's a fair bit buried in threads, but that could take awhile... If there is already a thread containing the information I'm after, please point me in the right direction and shut this one down.
So basically, due to issues with my stock computer pulling fuel/timing/giving DTC's etc, I'm considering the option of going to one of these full stand-alone ECU's. At this stage, I know my tuner can tune the VIPEC, have not spoken to him about the Link yet. From looking at the features, these two ECU's are very similar, which is why I'm making this thread. Could anyone with experience tuning or simply running these ECU's let me know how easy they are to tune, etc?
Secondly, there are a few main features that I am interested in:
1. I want to go forward facing plenum in the future, so individual cylinder correction is important. I know the Link can do it and I imagine the VIPEC can too, correct?
2. I also want to setup tables for IAT adjustment. Is there any advantage with one ECU over the other here, or is it much of a muchness?
3. The only motorsport feature I MAY consider using is traction control, though probably won't bother with that either. I have currently got a Greddy Profec controlling boost, so may not bother with boost control through the ECU unless it is really worth it?
4. Wideband input will also be important, though I believe they can both do this?
5. Flex fuel. I want to have the possibility of setting up flex fuel in the future, I think this is where the Link may come out on top. Does the VIPEC support an ethanol content sensor too?
And finally, QuickTune. I believe both ECU's have this, but exactly how good is it? It sounds great when described by the manufacturers, but is it really as easy as setting your desired AFR, plugging in a wideband and letting the ECU do it's thing or is it a bit more confusing than that?
Ease of use is probably one of the more important factors, which is why I'm interested in QuickTune so much. But any other advantages/disadvantages between the two that aren't so well explained could help me out too. I will speak to my tuner this week about them, so this may become a moot point, but any help in the mean time would be much appreciated :)
Cheers,
Martin.
  • Replies 96
Pretty sure the Vipec is just a rebadged Ling G4
Do you have a Hypergear turbo? If so you can get the Adaptronic Plug in for around $1200 comes with internal 4 bar map sensor.
$44 for the air temp sensor which you can wire into the ecu loom so its quite neat(I have some spare pins if you need one)
Has a great auto tune function.
Also can have traction controll(You need to hook into the front wheel ABS sensors), launch control and Andy(The creator) has just demoed how anti lag works on the ECU.
Only down side i can see is it is wastespark and semi sequential injection, this didnt bother me too much.
Yeh I did briefly consider the Adaptronic, but they don't make a plug in version for the 25DET Neo and when it's only another $300ish to get the Link or Vipec then I'd rather just pay that bit extra.
They are the same unit. Unless you are going to buy from the factory
http://www.linkecu.com/
just get the Vipec from your tuner which will give him his dealer margin and make him feel better disposed towards you!
So they are literally exactly the same? I thought I read that the Link came with a 7 bar map sensor while the VIPEC only has a 2.5. Must have read that wrong cos I can't find it now. Bit annoying because I want to run 23 psi :/
Another thing, where does the map sensor usually get installed? Is there much point going to the map based ecu if the sensor gets installed in the plenum given that I'm planning on changing to forward facing?
as above both are the same.
both have internal map sensors, should be able order either with upgraded map sensor.
auto tune function is ok. just input afr you want at what load point and will adjust fuel map, this requires a wideband to be hard wired to ecu.
go the vipec from your tuner :thumbsup:
you have to spec the G4 up to get the 7 bar sensor its not standard, standard vipec skyline plugin comes with 3bar anything post july 2011 from what i was told recently (2.5bar pre july 2011)
the map sensor is soldered to the ECU board, it requires a vac line be run from the inlet plenum into the cabin and to the ECU. it doesnt matter what inlet plenum you have unless you change it post ecu install and tune. MAP is sensitive to engine modifications if they improve engine efficiency they throw the tune out.
Ah, well if it comes with a 3 bar sensor then I'm all good.
So the vac line gets plumbed into the plenum? The plan was to change the ecu now to sort out the current problems and then change to a forward facing later down the track. I could still do that, though I guess I would have to get my tuner to install the plenum, could have done it myself.
There is a small built in map sensor but for serious boost you just get a higher value map sensor (doesn't have to be the Link one - I have a GM) which is bolted in the engine bay. It is wired to the ecu and the vacuum line goes to the plenum. It is not a big deal - most plenums will have multiple take-offs or you can put one on - its not a major and is easily transferred.
yes, the end result after the 11ty billion page Vipec thread (and what we all know) Vipec is a rebadged Link.
I think it's on the Link website somewhere saying that they (Link) "launched the Vipec brand" etc etc
So don't worry about which one can do what... they're the same thing.
I went to a link G4 from a nistune and it ironed out all my lil bugs id say go the G4 purely for the fact it goes into the stock ecu box so isnt really detectable. Ive seen pics of the vipec is it a bulky unit that will need to be mounted somewhere?
Id recommend getting the extension harness while your at it :)
A little cable that plugs into the board to give you a few extra's. Another 5v source, another ground and a couple inputs etc.
If you were planning on running alot of boost, then getting a bigger MAP sensor will take up another input. And if the car is a street car, there aint many left for other stuff.
Once you use the Boost solenoid input for boost control, the AFM input for IAT, and the narrowband input for Wideband..
You get the idea :)
Great ECU. Been running the GTS/GTR Link G4 for a year or so now.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
