im leaning more towards the +30*/35 because i want flush fitment not poke, plus the larger offset will clear big brakes if i ever upgrade.
im only running such a small tires because i have limited funds and dont want to buy new ones yet when i already have some 235's with 80% tread
Offset doesn't determine brake clearance. Spoke design does.
  • 1 month later...
Hey Guys,
This has been really helpful to read through, I'm ordering rims this week from Work, getting Meister s1 3 piece 18x10+31 and 18x11+29
going by what you guys are saying this seems ridiculous, but I would like to know what you think of offset for front/rear, as you can tell I'm going for a big 'dish' look.
I have Yellow Speed coil overs, will be getting a Type R body kit from viva garage, and universal flares to help fitment. Standard breaks for now but looking into a Brembo or Project Mu kit shortly.
Getting my head around offset has been hard, and I'd love to see some pictures of wheels to compare different offset types. I know what look I am going for, so much criticism about how much work I'll need to do, which I am aware of, I just need a basis to go off, and you all seem to know what works/what doesn't.
Cheers, Ellie :yes:
PS: this is the look I am going for, any ideas on the offset?
Edited by elleNEO
those wheels on David Lai's 34 are 19×11 -1 and 19×11 +3 pretty sure
if you have a non GTR 34 without any guard work you can fit 18x10+15 with a little poke or around +30 will make it more flush,
ive got 18x10+35 on my rears at the moment (non GTR no rear guard work), they sit a little in with no spacers, 5mm gets me flush and 10mm spacers get me just a tiny bit of poke. but with +35 my rim hits the coilovers if i slam them too much so id advise +30 at the rear max,
for the front i have 18x9+30 but i have GTR front guards so they have plenty of room, wish i went +15 on the front instead. but spacers will help me fill the gap anyway.
thats just what ive found with my 34 anyway, heres some pics for reference hopefully helps a little
5mm spacer in front and rears
How about this setup on my GTT, getting a sweet deal on a forged set so I thought I would consider this....
18x8.5 +30mm Fronts
18X10.5 +50mm (with 2" lip) Rears
car has BC racing coilovers coming, other then that the suspension is stock right now.
Will these work with the appropriate tires? would I need any spacers to make the rears fit better?
+ 50 on the rear is way to big for 10.5's, im pretty sure if i ran them on my 34 id need 30mm spacers for the rim to clear the coilover which would = massive poke resulting in major guard-work or a defect. (less offset should give you a bigger lip too)
im not an expert, just going off my past experience. and it all depends on how you want your wheels to sit.
im using BC coilovers as well and as i said in a above post my 18x10+35 on the rear hit my coilovers if i lower my car too much so i have to run spacers.
if you want a flush look id aim for 18x10+25/30 in the rear and add 5-10mm spacers to give you desired poke/flush look
im not too sure about your fronts as i have wider guards so i have more room then you but 18x8.5 +30 sounds like it would sit pretty well
hope that helps you
thanks for your help!
I actually went to see them, they are actually 18x8 in the fronts and 18x10 in the rears.
Since the seller had the sizing off I imagine he also was not correct with the offset being at +50 either. I could not find on the wheel the offset either.
I will be test fitting them shortly to see how they actually fit on the car, its the only way to be certain.
  • 3 weeks later...
I'm looking at a set of d1rs in 18x10+41 rear and 18x9+25 front I have rolled guards and nismo s tune suspension, I don't want camber and ridiculous stretch on my tyres, but I want the guards filled those offsets should clear okay and have room for my brakes still?
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
