What are the chances of fitting front : 19 x 9.0, +20
Rear : 19 x 10, +10
Currently running stock suspension but soon to get bc/br coilovers. I'm hoping I don't have to do any guard work
your gonna need some guard work but they should sit nice once your on BC's
Rear : 19 x 10, +10
As per what Dom said,
To give you an idea one of my previous setups was 18x9 + 20 front with 235's which was a pretty flush fit but no guard issues.
Currently running 18x9 + 20 with 235's front and 18x10+18 rears with 265's, have had all 4 guards rolled and have no issues , but without the guard work the rear would definitely not have worked.
I have 18X9.5 +22 all round. 235/40 front and 265/35 rear (had them spare with plenty of tread).
Rear is perfect for me but there is a bit of poke on the fronts though. I have BC Racing BR coilovers and thought that they had some degree of camber adjustment, apparently not. Thinking I may need camber arms to tuck them in a little... Thoughts?
Can't seem to attach photos dammit!
Edited by chrisR34GTT
I guess I missed that my bad That's a good reference guide for me thanks for that !
Im on standard rate, which I think is 8k and 6k? Someone correct me if im wrong
yeah im on 8/6 as well, perfect for street/daily
8/6 aswell had a friend driving mine "he owns a GTT aswell and reckons theyre smooth
Just to throw in an alternative, I'm running BC BR F:6/R:5 on R34 GTT sedan, along with bigger swaybars, F&R camber arms and F castor arms. Very happy with the ride.
with + 40 offset on a 10 inch wide wheel your going to have trouble clearing your rear suspension unless you use spacers or your still on stock ride height.
id go +30 max in the rear
  • 3 weeks later...
camber is not the answer, sure it may give you some appealing "stance" but you go any more then -2 deg on the front and you'll notice your steering change and become more darty/twichy.
if your on 0 camber then by all means add a little just dont go crazy, maybe raise your front a little, (my front bars on 100mm and my cross bar under my engine scrapes when i go to fast on uneven bumpy roads) so surly you cant be much lower then me and i have no issues but then i have 18x9 +30 to give me the clearance i need in the front.
what size are your tires, could go down to a 235 if there fairly wide currently, and are you running stock castor? and do you have any rubbing at full lock?
Edited by IMPORTS ONLY
yeah, im also digging that alignment thread somewhere, im on 100mm too, same scenario with yours, it kisses the fender bit. running on 235, yeah stock castor, yep rubs at full lock with plastic guard, so i took it off, still hit it over bumpy roads, i haven't done alignment and not keen on getting harder spring for my coil
lol you running teins too, just saw ur thread
Edited by enka
i did have tein HA's but they didn't get low enough in the front so swapped to BC BR's, if you get aftermarket adjustable castor arms you will be able to bring your wheels forward to around 6 degrees which will give you enough room to leave the plastics in as well as have a better steering feel (in my opinion) and if you just whack them in easy as and take it to a place like jax quick fit they can adjust it to where you want it fast and cheap, also maybe if you go down to a 225 you might just be able to get the tire under with no scraping but depends if like the stretched look or not
  • 1 month later...
Just taking the thread on a slight tangent as I have found most of the info I'm looking for , but I saw earlier in the thread the OP was considering lenso d1r's, are they any good quality wise? I'm guessing by the price they aren't forged...
  • 1 month later...
Hi Guys
I am wondering if this will fit without guard rolling and would they sit flush. Car Gtt 34
18x9 +35 offset. Versus Raceforge 2 Rims
Tyres 235/40/18
If not please advise.
Might be a bit tight on the front.
I couldn't fit 9.5 +38 on the front it was too inset and was hitting the suspension strut.
I went for ;
8.5 +30 on the front 245/40
9.5 +38 on the rear 265/35
  • Like 2
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
