Well tyres wernt designed to be stretched on to wheels larger then the suited size.. there for would be more prone to cause an accident wouldnt it? The added stress on the side walls cant be good for it? Plus why would you want to runn less tyre on the road..theyr the only thing keeping you on the road..so run the right size? My theory behind it anyway
Aren't you running 235 on a 18x9.5?
Looking at going 18x9.5 +24 all round now with 235/40/18
i know it will be a little bit of strech but from what arctic choc has and a few other people in skyline owners forum running 18x9.5 +30 i should sit nicely in the middle of it all correct?
Cheers Arctic! Less stretch than I thought. Looks good though.
Anyways problem is solved, FINALLY decided on wheels and bought them. Hoping they arrive by the end of the week.
I got work x jdm concept gt5 in 18x9 +30, which is the gar wheel size so pretty sure I shouldn't have to do much. They kind of look like drift teks but they're a proper work wheel which is sick. I'll post some photos when they're on
Cheers man, I'd been looking fro bronze wheels for ages but nothing seemed to be the right offset or size. so stoked on these.
yeah, when I bought the car, i cleaned them up but just havent satyed on top of it. Ive got some turtle wax 2 in 1 headlight cleaner I think. might give it a crack.
unfortunately when we did the wheels they guys notice a big bump in my sump, which might explain why my oil gets a bit warmer than usual. so next on the list is new sump and the cusco drag rod to get rid of that nasty Hicas.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
