Sorry, the older cars used to use 24/64-18 front 27/68-18
Looks like the newer cars went up some sizes. 27/65-18 and 31/71-18
Used tyres aren't that hard to come by, google will show a few leads.
as will my105.com.au
http://www.my105.com/ListingDetails/tabid/65/p/1/cid/5478/id/12962/Default.aspx
http://www.my105.com/ListingDetails/tabid/65/p/1/cid/5478/id/12958/Default.aspx
  • Like 1
yep, I bought a set of Kumho S700 because they were cheaper than semis at the time. Had 2 front blowouts in 3 track days, one left one right. And the third one I got to replace the first blowout, was smoking and about to let go when I had the 2nd blowout!
That was on a 180SX with unchanged front suspension setup that R888s and FZ201s, and even cheapo gemstone street tyres survived for years without any issue.
I wouldn't touch Kumhos again after that experience. And Kumho simply didn't want to know about it.
Edited by hrd-hr30
I have three sets of Kumho V70A's and I have been very impressed with them after coming from Yokohama 048's.
The Kumho's have a reputation for failures on the front if you run them too soft or with too much camber.
I had to go up about 6 pounds from the 048 hot pressures and I only run 2 degrees negative camber in the front.
It could be the fact that they have square shoulders and like to sit flat on the road but they seem to react badly to camber. The 048's have very rounded shoulders by comparison and cope with a lot more camber without any problems. The Kumho's also like higher pressures that seem more like street radial pressures than semi slick pressures.
I am happy with the performance of my Kumho semi's but you have to adjust your pressures and suspension to make them work. They are not as forgiving as other tyres on the market.
Weird.
I have the v70a/v700 ( arnt they the same?) in hard compound running on the supra, so a fairly heavy car. I havent had issue's with them and ive had them since start of the year, had 2 track days and 5 hill climbs so far.
I also ran them 34/32 hot for track days and even tried them at 32-30 hot on hill climbs, no issues for me.
I like them but would go mediums as the hard compounds take too long to heat up for hill climbs.
I hear very good things about the 050 yokohama's
Weird.
no the V700 and V70A are different types/patterns of semi slicks. But he was asking about slicks - i assume the V700 was a typo - the Kumho slick is S700. Which are obviously a different tyre from either of the semis.
Weird.
The 50's are quick but dont last very long. They also fall away in performance - not the compound - just the rubber wearing differently across the tread face. May be fixable by remounting the rhf on the lhf as they are directional. They go well from cold too.
That's opposite of what the IPRA guys were saying when the 050's came out. Compared to the 048's, which heat cycle badly, they reckon the 050's were good till they were at the canvas, hence better value for money as you can use them till they wear out and not lose performance.
Well that is why I was trying to say it isnt a compound thing. Just maybe that my lardbox is a little to, umm, lardie for them.
Am sure someone will be along to tell me my set up sucks teh balls but here is a dead tyre.
Not how the tread block (for want of a better term) wears - chamfers really. Can be helped by swapping tyres side to side but the grip does fall away as the tyre ages. For me anyway.
What pressures were/are you running?
Mine chamfered as well when I first put them on, a little more camber and less tyre pressure seemed to help a fair bit.
How do you rate them against the V70A for wear and grip?
1. Pressures were 30# which is what the bloke from Yokohama said.
2. Camber is enough I think - anymore I would have to wheel align it for other circuits/events etc. Dont think it is that far away. Did a 64.0 something which isnt too bad for 410 horsepowers, a full interior and a talentless driver.
3. NFI never ran with the ho's.
Yeah 30 hot is spot on although I think I'm running plenty more camber than you, I'm up to around 4deg now.
Thinking about giving the Kumhos a crack next, I've got the 123S down into the 63's and the A050 a mid 61.
Have a set of Ikeya Formula front LCA's to also fit so hopefully the extra track that gives will help times a little because GTR understeer is a bitch
Edited by SimonR32
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
