Those Nankangs look pretty good, unfortunately their 17's are not wide enough for mine http://nankangtyres.com.au/tyre/ar-1/
Have to say that my present Hoosiers are doing well, they are wearing very evenly across the tread with the shoulders holding up nicely, better than any other tyre I've tried. The other thing with Hoosiers is their sizing, plenty of 17" choice in 40 series which keeps the width up and the diameter down to help clear the guards. EG the 245/40 Hoosier is 622mm dia, 235/45 Hankook Z221 is 644, the difference allows me to use the wider 245's on the front, comparable Hoosier rears would be 275/40 only 648 dia.
I'm talking sprints where there is time to warm the tyres up, not time attack.
The Nankangs are brand new. I'm sure there'll be more sizes to come.
Of course you're not talking time attack when you mention Hoosier. Time attack have to use semis. Hoosiers aren't semis, they're 2 groove 'cheater slicks'. The latest ones aren't even 2 groovers, just a few broken dashes. Not semis by any stretch of the imagination.
The Nankangs could turn out to be good going on the Hankook success story. Price them cheaply to get them out there and let word of mouth do the rest then when they get popular stick the price up.
Tried them yet Harry? C'mon, get a move on.
  • 4 weeks later...
Tried the Nankangs out last week. Ran a best of 60.3 but that was not really representative of their potential - the admin people listed me as entering a Toyota Starlet instead of the Soarer that has been in their database for years, so I got put in a slow group with cars running over 15sec per lap slower!!! That's alot on a 60sec lap. I lapped that car twice in one session... As a result, I was only getting one or two clean laps each session to set a time.
Comparison to other tyres I've used - no car changes:
235 Hankook Z221 soft C70 compound 59.8
265 Nankang AR1 60.3
245 Nitto NT01 61.3
The rear doesn't stay quite as attached as the Hankooks did on the fast turn onto the front straight. Mid corner to exit they start letting go just slightly. Other than that they feel good. They should be a bit closer to the Hankook softs than those times were, but I don't think they're quite a match for them. That's still an awesome result for a tyre that's $209 per corner, compared to arguably the fastest tyre available!
Wear was very good. The only question mark over them is a strange circumferential line that's appeared around the center of each tyre - it's not quite straight. I don't know what it is. It runs the wrong way to be a tread splice. It's not from contact with the body as it's on all 4 tyres, and there's nothing to hit in the rear wheel wells. there's definite contact being made on the body in the front right - you can hear it in the left hander "Hungry" corner.
Edited by hrd-hr30
  • Like 3
I wonder how the NT01 in the same size would square up to the Nangers.
From what I'm seeing they perform well for you, but the adult in me is telling me to never buy Nankangs again because I'm not 18 anymore.
  • Like 1
Pretty keen to try the nankang ar1s to be honest quite cheap.Might give them ago next round of tyres im only on kenda kr20a and nakang ns20r at the moment so would expect large improvement
I'd never buy NT01s again! Better off buying RSRs.
That's a strange result for RSR v NT01... Normally not that far off the pace of NT01, which is pretty god for a non R comp, alot cheaper, road legal etc
First I've heard of RSR delaminating too. Tread splice opening yeah, but delaminating?
Edited by hrd-hr30
When I reported it to federal they considered it delaminating. We are probably talking about the same thing here.
I don't think it's strange at all. Rsr lasted maybe 2/3 hot laps and then greased over, Nt01 I could go harder and get about 5 hot laps before they overheated.
But nt01 is still only a introductory semi whereas rsr is very much a street tyre.
Why would you never buy nt01 again?
1. They're the slowest semi money can buy.
2. They're not road legal so you can't even legally drive to the track on them which is a PITA.
3. They're not CAMS approved for production car classes.
You're better of doing very similar times on street tyres, or buying literally any other semi (other than R888 :P)
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
