Yeah I understand that
I will be running 50/50 with the tune.
Everyone can drive off boost so even of I run out its not the end of the world you can still drive around off boost right? Just not thrash it
If you did that you would have to be extremely careful not to ever come onto boost if you had really ramped up the boost / timing with the WM mixture injecting. Otherwise good bye motor very very quickly! I wouldn't feel comfortable driving it around like that for any period of time!
Just get a float sensor for the tank and a warning light, and carry some extra WM with you. Or invest in a failsafe device.
I recently bought the AEM failsafe device which looks very good. I will use it to trigger a second map in the ECU.
Hes got a float sensor/warning light already yeah.
I would aim to have it tuned with 2 stages of boost, where the low boost is perfectly fine without the WMI and the high boost is WMI dependant.
Best of both worlds :thumbsup:
Maybe get a fail safe and wire it up so that it will kill the power/remove the ground to your boost controller when it's triggered. That way if you run out it'll just run off gate pressure which is better than nothing...
Pretty sure snow make a safe injection/fail safe type thing, but most brands will probably work with your kit.
Edited by Mitcho_7
  • 1 month later...
Im going to try install a air/water atomiser inbetween the turbo and airflow meter and see if it works. Get rid of the pump
system. Don't know anyone thats tried it so will be suck and see, to see if the air upsets anything...
cheers
darren
Compressor wheel erosion will occur.
Errr, i know you know a lot...but your wrong this time, very wrong ..done it heaps of times...only air sprays wear out wheels..air/atomisers do not
the air side of breaks the water down into much more fine microns than shitty arse chinese bilge pump setup...lol. My coolingmist
kit even with there new fange dangled super atomiser is no where near as fine as my air/water atomiser....
I have done this, more than once... so i speak from experience, i didn't read about it on the net inbetween masturbating
on redtube..lmao
cheers
darren
Edited by jet_r31
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
