Yeah I understand that
I will be running 50/50 with the tune.
Everyone can drive off boost so even of I run out its not the end of the world you can still drive around off boost right? Just not thrash it
If you did that you would have to be extremely careful not to ever come onto boost if you had really ramped up the boost / timing with the WM mixture injecting. Otherwise good bye motor very very quickly! I wouldn't feel comfortable driving it around like that for any period of time!
Just get a float sensor for the tank and a warning light, and carry some extra WM with you. Or invest in a failsafe device.
I recently bought the AEM failsafe device which looks very good. I will use it to trigger a second map in the ECU.
Hes got a float sensor/warning light already yeah.
I would aim to have it tuned with 2 stages of boost, where the low boost is perfectly fine without the WMI and the high boost is WMI dependant.
Best of both worlds :thumbsup:
Maybe get a fail safe and wire it up so that it will kill the power/remove the ground to your boost controller when it's triggered. That way if you run out it'll just run off gate pressure which is better than nothing...
Pretty sure snow make a safe injection/fail safe type thing, but most brands will probably work with your kit.
Edited by Mitcho_7
  • 1 month later...
Im going to try install a air/water atomiser inbetween the turbo and airflow meter and see if it works. Get rid of the pump
system. Don't know anyone thats tried it so will be suck and see, to see if the air upsets anything...
cheers
darren
Compressor wheel erosion will occur.
Errr, i know you know a lot...but your wrong this time, very wrong ..done it heaps of times...only air sprays wear out wheels..air/atomisers do not
the air side of breaks the water down into much more fine microns than shitty arse chinese bilge pump setup...lol. My coolingmist
kit even with there new fange dangled super atomiser is no where near as fine as my air/water atomiser....
I have done this, more than once... so i speak from experience, i didn't read about it on the net inbetween masturbating
on redtube..lmao
cheers
darren
Edited by jet_r31
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
