Yeah I understand that
I will be running 50/50 with the tune.
Everyone can drive off boost so even of I run out its not the end of the world you can still drive around off boost right? Just not thrash it
If you did that you would have to be extremely careful not to ever come onto boost if you had really ramped up the boost / timing with the WM mixture injecting. Otherwise good bye motor very very quickly! I wouldn't feel comfortable driving it around like that for any period of time!
Just get a float sensor for the tank and a warning light, and carry some extra WM with you. Or invest in a failsafe device.
I recently bought the AEM failsafe device which looks very good. I will use it to trigger a second map in the ECU.
Hes got a float sensor/warning light already yeah.
I would aim to have it tuned with 2 stages of boost, where the low boost is perfectly fine without the WMI and the high boost is WMI dependant.
Best of both worlds :thumbsup:
Maybe get a fail safe and wire it up so that it will kill the power/remove the ground to your boost controller when it's triggered. That way if you run out it'll just run off gate pressure which is better than nothing...
Pretty sure snow make a safe injection/fail safe type thing, but most brands will probably work with your kit.
Edited by Mitcho_7
  • 1 month later...
Im going to try install a air/water atomiser inbetween the turbo and airflow meter and see if it works. Get rid of the pump
system. Don't know anyone thats tried it so will be suck and see, to see if the air upsets anything...
cheers
darren
Compressor wheel erosion will occur.
Errr, i know you know a lot...but your wrong this time, very wrong ..done it heaps of times...only air sprays wear out wheels..air/atomisers do not
the air side of breaks the water down into much more fine microns than shitty arse chinese bilge pump setup...lol. My coolingmist
kit even with there new fange dangled super atomiser is no where near as fine as my air/water atomiser....
I have done this, more than once... so i speak from experience, i didn't read about it on the net inbetween masturbating
on redtube..lmao
cheers
darren
Edited by jet_r31
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
