Finally got through your thread Paul!! There is so much sh*t talk in here....
I think my SR is the engine that finally converted Paul to going to the dark side with a single.
Here is an overlay of my car (black dots) over Paul's graph. I'm running same boost in the midrange but mine doesn't fall over up top. Both are on Yavuz's dyno. Somehow I don't think its the engine alone (it is a built and stroked VE sr) and the turbo has a lot to do with it (6262).
Pretty interesting it made more power down low and also more up top with some losses in the midrange.
Yavuz wanted to keep going, adding more boost but I reckon that is more than enough.
Also, FWIW and those interested in buying a manifold, I had a extremely ordinary service and product experience with Alpha Omega....
pretty interesting. It would have been interesting to see how far you could have gotten to with the boost, but like you said, thats pretty ample for a sil! I have seen the graph, and for a turbo of its frame and capacity, it almost makes you wonder how it does it. I have also jumped onto the PT bandwagon, cant wait too see the results :)
Hi James - you are very quick around the creek (1.39.6) & wakefield (1.04.07) with < 300kw
Must be a weapon of a car!
Thanks Marko. Its definitely 'interesting' to drive even with the old 265. Still haven't got to drive it since the new engine, its just a dyno figure at this stage!! Just have some niggly issues I want to get right before I get it properly tuned.
Don't to clog up Pauls thread. Build thread is here if you're interested - http://www.nissansilvia.com/forums/index.php?showtopic=520202
I agree. I thought it would be quite a bit laggier. I was a bit worried it might not really come on until 4200-4500. The precisions aren't really good quality though... I don't have much faith in it lasting... The casting and bearing and general fit and finish is a bit average but we'll see how long it lasts. I'm not expecting much though to be honest. The wheels are just so much better than garrett though its just too hard to ignore.
Time will tell James. There was a hell of a lot of PT's at WTAC and I didn't hear of any failures.
But surprised they're not watercooled though. Must be some reason for that!
yeah. Interesting about the lack of water cooling on these turbos. But then again, they were around for a looooong time without it too. A random stab may be to keep it in a particular heat range to get the best out of it. Ive seen and heard of weirder things lol
A little update.
Got the engine back on Friday arvo. Can't get some of the pics to work. Stupid things.
Manifold to gasket size.
Exhaust port to gasket.
Another picture.
Turbo's are almost done. Just need to do the drains and the top lines. I stopped because the sun was burning me! haha
Slack! Definitely starting to come together.
As mentioned in PM very keen to see the overlays from the twins to the single PTE
Oh there will be graphs, when I don't know. After being off the road for so long I want to enjoy it for a while. I'll cant help to think I've gone a bee's dick big. There will be a 6262 thrown on and tried too at some point.
duno if i missed it some where but what Tomei stroker kit is it? (cooling chanel? tiatan coating? normal kit?)
and are you running this on pump fuel?
Tomei 2.8
Non cooling channel. Had 2 thou clearances the last engine and never had issues.
Top ring is Ti coated. (last engine had a standard Tomei top ring).
I have the "flex fuel setup". So when I'm belting it, it will have E85 in it. On the street it will have anything between E85 and PULP.
Tomei 2.8
Cheers mate, i was looking into the kits last night coz i think it will be easier to just chuck in a 2.8 crank rods and pistons into my engine already as thats all id need to change instaed of going 3L.
you can re use the existing head studs and all that stuff right? just need new head gasket and bearings?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
