I agree, turn down the wick mate and enjoy...besides, your car is stupidly or cn I say dangerously powerful
slap stocker box in
adjust wastegates to 17pis
enjoy for a long time without issues
will save you 7k
downside is less blokes on here humping your leg due to awesome output
It's at 25 psi man. Hardly "screwing its brains out" and realistically I haven't run over 22 psi at all which is less than what most people run on -5's. if I turn it down I may aswell drop back a turbo size. There are associated costs with doing that too.
sorry to hear bout the box :(
interesting though, with E85 and new turbo tech, starting to really push the boundaries of what street cars would normally have to contend with. Maybe you'll create a market for a street-able bullet proof gearbox option - but you've unwittingly created a bit of a "ceiling" for what people might be considering build wise as well... (With respects to gearboxes)
not sure if it's of much help, but i recently found out i have 33 v-spec ratio diffs (like a god damn kinder surprise this car) soooo... i have a getrag and 33 diffs... if you're in melb anytime soon, you're welcome to take it for a drive if you like, see what you think. She might be a bit slow for you, but she goes alright :D
Torque ratings ain't high enough. Try again lol
Phone them. I bet higher ratings are available.
If you had a high reving 2.6 with less torque, this wouldn't be a problem.
Edited by black bnr32
I believe he is in Vic ATM for DECA this weekend, what revs does it sit on at 110
go on Paulie get the OS88, you know deep down you want it, and then I can take it for a drive and see if I want one :P
What timing! I'm actually in Melbourne right now! Thanks for the offer Dan. Flick me your number so we can organise something. That would be fantastic. I've always wanted to launch a Nur spec from 10,000 RPM :P
What a great clip.
that thing is an animal!
Is it just me or does the gear changing sound slow for a sequential box? I don't know much about them so maybe there is a setting for gear change delay.
may the sequential be with you... always
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
