Hnm, never heard of egt straight into ecu, as they are in the millivolts range usually need to be amplified 150 times (or was it 105?) To get it into the 0-5v range.
Keen to see what he comes up With none the less, putting provisions in for mine but jsut running the single behind the turbo as an overheat protection for the turbine wheel.. for now.
I have also been looking into this and everything I have seen connects to a separate box. I think I'll be going with the link setup that connects via can bus
Yep or a transducer of some sort
  • 3 weeks later...
2 hours ago, fatz said:
Lol head gasket for more that 17psi
tomie turbos
lol
mr speed hunter is living 5 years ago
Dont worry man
Those tomei turbos wont make 17psi until 9000rpm anyway
  • Like 1
17 minutes ago, Count Grantleyish said:
'cause you love Tomei stuff.
There is very few Jap things on my car. Only Tomei thing is the stroker kit. IF it fails again I'll go bigger!
Tomei turbo's won't find themselves on my car, however. First reason. They're twins. Second reason, they're journal bearing shit. Thirds reason, they're twins. ?
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
