Update!
Fuel system is almost completed.
- Aftermarket Industries SP 1200 using 2 of the possible 3 Walbro 460's.
- Speedflow 200 series black braid hose. -10 all round with a -12 breather.
- Had a fuel hat spun up to accept the factory rubber.  (This is away getting machined up to accept the fittings ATM).
- Ethanol sensor in the return line which has a bypass around it. The by pass has a 1 or 2 psi one way valve in it to push as much fuel through the sensor.
- Hypertune rail which got annodised black.
- Bosch 1700 cc injectors.
- 3 X Fuelab 828 series (5 inch long element) fuel filters. 1 is a 40 Micron pre surge tank, the other 2 are 6 Micron in parallel post surge tank.
2CF376C8-F2E3-434C-9386-B6E1350FE8E3_zps
A6DDED2F-8525-4E93-A760-673303052EB7_zps
A9AD71BB-3BA7-45EE-A1FA-EC717370AF53_zps
026C0C1E-F8DC-4093-B6D3-13F391CF15F2_zps
7BF24C45-2074-4137-9343-EB7C5B230BC0_zps
Got the reground HKS V-Cam back. It started life as a 264 @ 8.7 mm. Duration at 50 thou was 222.xx. It's not a "270 ish" @ 10.25 mm. Duration at 50 thou is 229.54. The Unigroup "260" at 50 thou is 232.34, so a little more agro. That has 10.85 mm. The Base circle went from 32 to 30.1 mm on the modified V cam camshaft.
6C3C5B4F-3B3C-41BF-8285-BB6C554ED74D_zps
Unigroup cam left, V cam right.
ED49E84C-7B67-4B37-9C4E-E4AC5ADE3A2D_zps
Unigroup left, V cam right.
4193B74B-353B-4636-A911-3067EC1D2DA2_zps
Unigroup left, V cam right. You can see the different sizes of the nose between them. Totally different, not to mention all the oil gallery machining going on in there.
  • Like 3
50 minutes ago, Sub Boy32 said:
Sweet looking fuel setup.....as usual for you overkill is the name of the game!
this is going to be a very scary car when it hits the road!
Means I'll NEVER have to revisit it again. Done!
  • 1 month later...
On 11/20/2016 at 7:39 AM, Sub Boy32 said:
Some finger from arse removal is required here.......:bomb_ie:
Can't get into Insight until Feburary.
Haven't spoken to Dennis this week. Hopefully the PS res, the airbox and gate lines are on the to do list.
Gearbox is back out of the car. I wish I knew this before I put the gearbox in, but for those who buy an OS88 in the future, make sure you sort out the breather fitting. They silicon the fitting in and with a little bit of heat the fitting pops out. It makes sense why it was spewing oil out on the dyno and on the road! Box is at Award getting sorted. So, a "cover" on the inside over the breather hole, a tapped thread for the breather fitting so it won't come out. Scott also wants to run a Mercedes Benz gear position sensor so that will go in now. GRRRRR!!!!!
Ross CAS kit was ordered last week.
Godzilla motorsport ignition kit ordered this arvo. Thats another two items off the list.
  • Like 1
It was easier to get to the moon :)
and quicker . lol
16 hours ago, fatz said:
Buy the time this car runs the turbo will be outdated
#skolaspec
I see what you did there :D
Edited by reaper
  • 1 month later...
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
