Update!
Fuel system is almost completed.
- Aftermarket Industries SP 1200 using 2 of the possible 3 Walbro 460's.
- Speedflow 200 series black braid hose. -10 all round with a -12 breather.
- Had a fuel hat spun up to accept the factory rubber.  (This is away getting machined up to accept the fittings ATM).
- Ethanol sensor in the return line which has a bypass around it. The by pass has a 1 or 2 psi one way valve in it to push as much fuel through the sensor.
- Hypertune rail which got annodised black.
- Bosch 1700 cc injectors.
- 3 X Fuelab 828 series (5 inch long element) fuel filters. 1 is a 40 Micron pre surge tank, the other 2 are 6 Micron in parallel post surge tank.
2CF376C8-F2E3-434C-9386-B6E1350FE8E3_zps
A6DDED2F-8525-4E93-A760-673303052EB7_zps
A9AD71BB-3BA7-45EE-A1FA-EC717370AF53_zps
026C0C1E-F8DC-4093-B6D3-13F391CF15F2_zps
7BF24C45-2074-4137-9343-EB7C5B230BC0_zps
Got the reground HKS V-Cam back. It started life as a 264 @ 8.7 mm. Duration at 50 thou was 222.xx. It's not a "270 ish" @ 10.25 mm. Duration at 50 thou is 229.54. The Unigroup "260" at 50 thou is 232.34, so a little more agro. That has 10.85 mm. The Base circle went from 32 to 30.1 mm on the modified V cam camshaft.
6C3C5B4F-3B3C-41BF-8285-BB6C554ED74D_zps
Unigroup cam left, V cam right.
ED49E84C-7B67-4B37-9C4E-E4AC5ADE3A2D_zps
Unigroup left, V cam right.
4193B74B-353B-4636-A911-3067EC1D2DA2_zps
Unigroup left, V cam right. You can see the different sizes of the nose between them. Totally different, not to mention all the oil gallery machining going on in there.
  • Like 3
50 minutes ago, Sub Boy32 said:
Sweet looking fuel setup.....as usual for you overkill is the name of the game!
this is going to be a very scary car when it hits the road!
Means I'll NEVER have to revisit it again. Done!
  • 1 month later...
On 11/20/2016 at 7:39 AM, Sub Boy32 said:
Some finger from arse removal is required here.......:bomb_ie:
Can't get into Insight until Feburary.
Haven't spoken to Dennis this week. Hopefully the PS res, the airbox and gate lines are on the to do list.
Gearbox is back out of the car. I wish I knew this before I put the gearbox in, but for those who buy an OS88 in the future, make sure you sort out the breather fitting. They silicon the fitting in and with a little bit of heat the fitting pops out. It makes sense why it was spewing oil out on the dyno and on the road! Box is at Award getting sorted. So, a "cover" on the inside over the breather hole, a tapped thread for the breather fitting so it won't come out. Scott also wants to run a Mercedes Benz gear position sensor so that will go in now. GRRRRR!!!!!
Ross CAS kit was ordered last week.
Godzilla motorsport ignition kit ordered this arvo. Thats another two items off the list.
  • Like 1
It was easier to get to the moon :)
and quicker . lol
30 minutes ago, fatz said:
Buy the time this car runs the turbo will be outdated
#skolaspec
Hardly in my control. If I could of had it back by now I would! :mad:
#skolaspec
I see what you did there :D
Edited by reaper
  • 1 month later...
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
