Update!
Fuel system is almost completed.
- Aftermarket Industries SP 1200 using 2 of the possible 3 Walbro 460's.
- Speedflow 200 series black braid hose. -10 all round with a -12 breather.
- Had a fuel hat spun up to accept the factory rubber.  (This is away getting machined up to accept the fittings ATM).
- Ethanol sensor in the return line which has a bypass around it. The by pass has a 1 or 2 psi one way valve in it to push as much fuel through the sensor.
- Hypertune rail which got annodised black.
- Bosch 1700 cc injectors.
- 3 X Fuelab 828 series (5 inch long element) fuel filters. 1 is a 40 Micron pre surge tank, the other 2 are 6 Micron in parallel post surge tank.
2CF376C8-F2E3-434C-9386-B6E1350FE8E3_zps
A6DDED2F-8525-4E93-A760-673303052EB7_zps
A9AD71BB-3BA7-45EE-A1FA-EC717370AF53_zps
026C0C1E-F8DC-4093-B6D3-13F391CF15F2_zps
7BF24C45-2074-4137-9343-EB7C5B230BC0_zps
Got the reground HKS V-Cam back. It started life as a 264 @ 8.7 mm. Duration at 50 thou was 222.xx. It's not a "270 ish" @ 10.25 mm. Duration at 50 thou is 229.54. The Unigroup "260" at 50 thou is 232.34, so a little more agro. That has 10.85 mm. The Base circle went from 32 to 30.1 mm on the modified V cam camshaft.
6C3C5B4F-3B3C-41BF-8285-BB6C554ED74D_zps
Unigroup cam left, V cam right.
ED49E84C-7B67-4B37-9C4E-E4AC5ADE3A2D_zps
Unigroup left, V cam right.
4193B74B-353B-4636-A911-3067EC1D2DA2_zps
Unigroup left, V cam right. You can see the different sizes of the nose between them. Totally different, not to mention all the oil gallery machining going on in there.
  • Like 3
50 minutes ago, Sub Boy32 said:
Sweet looking fuel setup.....as usual for you overkill is the name of the game!
this is going to be a very scary car when it hits the road!
Means I'll NEVER have to revisit it again. Done!
  • 1 month later...
On 11/20/2016 at 7:39 AM, Sub Boy32 said:
Some finger from arse removal is required here.......:bomb_ie:
Can't get into Insight until Feburary.
Haven't spoken to Dennis this week. Hopefully the PS res, the airbox and gate lines are on the to do list.
Gearbox is back out of the car. I wish I knew this before I put the gearbox in, but for those who buy an OS88 in the future, make sure you sort out the breather fitting. They silicon the fitting in and with a little bit of heat the fitting pops out. It makes sense why it was spewing oil out on the dyno and on the road! Box is at Award getting sorted. So, a "cover" on the inside over the breather hole, a tapped thread for the breather fitting so it won't come out. Scott also wants to run a Mercedes Benz gear position sensor so that will go in now. GRRRRR!!!!!
Ross CAS kit was ordered last week.
Godzilla motorsport ignition kit ordered this arvo. Thats another two items off the list.
  • Like 1
It was easier to get to the moon :)
and quicker . lol
30 minutes ago, fatz said:
Buy the time this car runs the turbo will be outdated
#skolaspec
Hardly in my control. If I could of had it back by now I would! :mad:
#skolaspec
I see what you did there :D
Edited by reaper
  • 1 month later...
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
