Update!
Fuel system is almost completed.
- Aftermarket Industries SP 1200 using 2 of the possible 3 Walbro 460's.
- Speedflow 200 series black braid hose. -10 all round with a -12 breather.
- Had a fuel hat spun up to accept the factory rubber.  (This is away getting machined up to accept the fittings ATM).
- Ethanol sensor in the return line which has a bypass around it. The by pass has a 1 or 2 psi one way valve in it to push as much fuel through the sensor.
- Hypertune rail which got annodised black.
- Bosch 1700 cc injectors.
- 3 X Fuelab 828 series (5 inch long element) fuel filters. 1 is a 40 Micron pre surge tank, the other 2 are 6 Micron in parallel post surge tank.
2CF376C8-F2E3-434C-9386-B6E1350FE8E3_zps
A6DDED2F-8525-4E93-A760-673303052EB7_zps
A9AD71BB-3BA7-45EE-A1FA-EC717370AF53_zps
026C0C1E-F8DC-4093-B6D3-13F391CF15F2_zps
7BF24C45-2074-4137-9343-EB7C5B230BC0_zps
Got the reground HKS V-Cam back. It started life as a 264 @ 8.7 mm. Duration at 50 thou was 222.xx. It's not a "270 ish" @ 10.25 mm. Duration at 50 thou is 229.54. The Unigroup "260" at 50 thou is 232.34, so a little more agro. That has 10.85 mm. The Base circle went from 32 to 30.1 mm on the modified V cam camshaft.
6C3C5B4F-3B3C-41BF-8285-BB6C554ED74D_zps
Unigroup cam left, V cam right.
ED49E84C-7B67-4B37-9C4E-E4AC5ADE3A2D_zps
Unigroup left, V cam right.
4193B74B-353B-4636-A911-3067EC1D2DA2_zps
Unigroup left, V cam right. You can see the different sizes of the nose between them. Totally different, not to mention all the oil gallery machining going on in there.
  • Like 3
50 minutes ago, Sub Boy32 said:
Sweet looking fuel setup.....as usual for you overkill is the name of the game!
this is going to be a very scary car when it hits the road!
Means I'll NEVER have to revisit it again. Done!
  • 1 month later...
On 11/20/2016 at 7:39 AM, Sub Boy32 said:
Some finger from arse removal is required here.......:bomb_ie:
Can't get into Insight until Feburary.
Haven't spoken to Dennis this week. Hopefully the PS res, the airbox and gate lines are on the to do list.
Gearbox is back out of the car. I wish I knew this before I put the gearbox in, but for those who buy an OS88 in the future, make sure you sort out the breather fitting. They silicon the fitting in and with a little bit of heat the fitting pops out. It makes sense why it was spewing oil out on the dyno and on the road! Box is at Award getting sorted. So, a "cover" on the inside over the breather hole, a tapped thread for the breather fitting so it won't come out. Scott also wants to run a Mercedes Benz gear position sensor so that will go in now. GRRRRR!!!!!
Ross CAS kit was ordered last week.
Godzilla motorsport ignition kit ordered this arvo. Thats another two items off the list.
  • Like 1
It was easier to get to the moon :)
and quicker . lol
16 hours ago, fatz said:
Buy the time this car runs the turbo will be outdated
#skolaspec
I see what you did there :D
Edited by reaper
  • 1 month later...
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
