16 minutes ago, sneakey pete said:
Don't think there'd be the space between the rad support andt he bonnet?
Tried to find a photo... failed. I'll find it... somewhere but it has been done. Not sure if they modified the snorkle but I don't remember it looking "not factory".
There's no over the radiator support intake on the 32's. Just a oval intake under the headlights that clips into the airbox. There's also a port between the in engine bay and the behind front bumper area on side behind the factory wiper washer bottle. How many intake options do you get on the 33's?
  • Like 1
I know that, but it looked like they used a 33 snorkle. Grab one and see if it fits, even if it doesn't, it can't be that hard to make work.
Must be getting excited seeing the finishing touches coming together:1311_thumbsup_tone2:
A shame you have to earn the $s before you can put this type of build together , just hope I live to see it done, thought of getting a 3rd job, lol
You must take some vids when you turn the key for the first time, it will be one mad Boat:530_checkered_flag:
1 hour ago, SimonR32 said:
Piggaz vs Bobby for longest build and never driven...
But I do joke, keen to see some results on this mate, well Bobby's as well because that will be the joke :)
The zombie apocalypse will come before this car is ready
  • Like 1
  • 1 month later...
Car is finally booked into Insight on the 19th of April for the ECU, fuel system and sensor wire in plus the tune. Thats the good news. The bad news is that V-cam aint gonna fit with my pistons and how my engine has been setup. I had a chat with the bloke who screwed it together and with my positive deck height (+22 thou higher than factory), decked head, larger valves and god knows what, the only way to do it is to have a set of pistons made up with a thicker crown.... I'm not doing that!
So, bring on the 19th! Hopefully it runs before end of financial year!
Update of engine bay. All thats left to do it swap the harmonic balancer over annndd thats it.
D91B0863-1182-4E4C-8370-94E66E31EF9B_zps
  • Like 10
3 minutes ago, acsplit said:
Good good, don't worry it won't need the Vcam.
Because single and not twins? ?
Vcam WILL come. Just not yet. I want it on the road, not another rip apart!!!!
5 minutes ago, fatz said:
No need to change computers then if no v cam
More to It then that Pete.  That was more of a personal issue and a "f**k you" then anything.
Its done, it's dusted, whatever.
Just want it running. I have a date, that's it. Get it on the road!!!
1 minute ago, Deano 1 said:
Soooo no Emtron?
Emtron KV8 is a goer. Just no v cam. Box that guy up and save it for the inevitable rebuild... we all know how RB's are ?.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
