Suppppper early days. Scotty mapped the gearbox, the thing shifts like silk. It ain't spewing oil out either which is good! Got a misfire on cylinder 5, will look into that tomorrow.
18 psi by 3700 ish RPM on petrol with cams set at 0/0.
V cam looks like it would have been a waste of time. Scott can get it to surge at 2500 RPM. Need a 9180 [emoji23].
25 kw behind at 3700 rpm compared to my full effort -5 E85 run.... on petrol... with a misfire.
Yes yes, good good. Shame it's not an RB30 you could stop there
V cam looks like it would have been a waste of time. Scott can get it to surge at 2500 RPM. Need a 9180 emoji23.png.
Would have to. RB30's don't rev... or something ?
On 19/09/2017 at 8:56 PM, Nismo 3.2ish said:
Great to hear it is all going good mate and cannot wait for to see it tuned up on E85 and in full flight :521_rocket:
When are you strapping the 9180 on :)
Thats more a question for you Mr 3.2L V cam ?
HAHA, piss off Mick, I have enough up top and now it's time for more down low and watch it go :)
No upgrades yet Johnny , trying something soon but not sure if it will make much difference and will post the results , if any :/
  • Like 1
There is one part of it I reckon has a fairly good chance to, look forward to seeing how it goes though :)
V cam looks like it would have been a waste of time. Scott can get it to surge at 2500 RPM. Need a 9180 ?.
Mate 273.1KW...  You are barely behind my -7's at full flight hahahahhaha
Just race from traffic light to traffic light and you'll be fine, maybe?
A mate of mine still gives me shit about chopping my old GT-R in his Bluebird when I had a busted AFM lol
you still have AFM?
This needs to be entered in the street car 1/4 mile championship... you know the one for registered cars with h pattern boxes that is currently dominated auto sq wide body r32s with nitrous
kebab racing runs a 7.4
step up pigsarse
40 minutes ago, Anfanee said:
Turbo isn't the size of a small planet but the car is :4_joy:
Sorry pigz, this car is going to be mental. When does it go up for the full tune?
I believe Scott is spending all day on it today. No idea where it's all upto apart from the information I've posted.
Cant see it making anymore than 480 awkw. That's as much as Scott has seen out of a 8374.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
