Fuel doesn't have any idea how many cylinders the combustion chamber its being squirted into is joined up to ;)
Ultimately the harder the work the fuel has to do, the more E85 comes into its own... but you can still definitely get gains. I've seen from 3-7% from E85 on a naturally aspirated engine, depending on a variety of things. The most magical results I've seen are on highish compression turbo setups running a bunch of boost though.
With a relatively stock V8 I'd say the extra fuel usage would outweigh the gains, unless you have exhausted all alternatives and not worried about the ~35% extra fuel usage - and the fuel system upgrade you are likely to need to do to support that fuel usage.
If you were going to drop a decent turbo or two into the mix then E85 very quickly starts coming into its own.
https://www.sau.com.au/forums/topic/400917-e85-fuel-on-v8/#findComment-6368986
Any engine tuned to run on E85 will see some power benefits, but these benefits are much more obvious with engines that are prone to detonation or high heat, as high octane and reduced temperatures are the mainstay advantages of E85 over unleaded. Thus forced induction engines benefit greatest from it, but there's no reason you can't advance the hell out of the timing on an N/A V8 and see some good gains there.
https://www.sau.com.au/forums/topic/400917-e85-fuel-on-v8/#findComment-6368996
6% is still 6% , is that throughout the revrange or just a top end figure..I was thinking e85 could help gain some midrange..
My missus has a 3L Accord. its a zippy tank. but unfortunatly there isnt alot that can be done with it as the auto box is subject to failure even in stock form.
I think the comp ratio is 10.1, Now I read a thread where a guy just filled his up with E85 ,with stock everything and no additional tuning he was pulling at least a car length on a similar car on pulp..he ran it for a while with no issues but finally saw reason that it might not be the greatest idea without a proper tune
I have been very tempted to get an emanage or something, open up the exhaust a little and just tune for e85 to see what gain could be had..A 10% top end at absolute best, would be all I would expect, but more importantly I am interested in the low to midrange gain it could have as that is where it gets driven most..
i have been running it on e10 for ages without issue and getting great fuel economy as well, almost equal to BP98.
There will be little gain with stock compression. Chuck some 13:1 comp pistons in and it'll be a whole different story!
And biannual headgasket replacements...lol ..this was always the best way to make a V8 (or any NA for that matter) move anyway
https://www.sau.com.au/forums/topic/400917-e85-fuel-on-v8/#findComment-6371367
Well all you really need is a bigger pump and maybe a bit of extra pressure should work to some extent..At worst you get bigger injectors...
But i see where your going, Injectors,pump,piggyback,your looking at least 2000$ for for only a 5-10% increase...
Though if you already have these mods in place you have nothing to lose..and plenty of people have spent more for less
https://www.sau.com.au/forums/topic/400917-e85-fuel-on-v8/#findComment-6371658
  • 5 months later...
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
