Over the last coupla years, I've managed to pick up
nismo key, fashion lighter, paperwork case, floormats, clear front & side indicators, fuel pump, billet oil cap, high-pressure radiator cap, timing belt, LM GT4 18" bronze rims, s-tune wheel lug nut set, s-tune air valve cap set, 480cc injectors, solid shifter, dash cluster, engine mounts
I did have the nismo 3-gauge dash cluster, but I've since replaced with a GTR MFD (non-nismo).
All parts have seemed like the highest quality to me. I'm more than happy to buy Nismo. The key was probably the hardest - I nearly picked one up in 2007, but fell through - and recently managed to pick one up uncut. I'm always on the look-out for nismo parts :)
  • 4 weeks later...
Need a keen eye here guys. Looking at buying this Nismo Duracon shifter which looks hella cheap:
http://www.ebay.com.au/itm/NISMO-Duracon-Gear-Shift-Knob-Manual-Black-Nissan-/110878560606?pt=AU_Car_Parts_Accessories&hash=item19d0e0915e
It looks the goods, the packaging looks legit (I own another Nismo shifter) but the price is throwing me off. What do you guys think?
http://www.ebay.com....=item19d0e0915e
i have the same one and got mine for that price through performance wise.. was told it was genuine, looked good in packaging, feels good in the car.. still not 100% its 100% genuine, but it does do the job! and hasnt worn crazily in the 4 months or so ive had it for. so im not really fussed either way. also purchased other parts through performance wise so i tend to believe its genuine.. they may have over stocked them in Japan and now offloading them cheap?
I <3 Nismo gear, it's just faultless
So far I've tracked down and installed
Nismo Ti Strut Brace
Nismo LMGT4's in Silver
Nismo S-Tune suspension
Nismo Rear Member Brace Kit
Nismo Floor Brace Set
Nismo Lug Nuts
Nismo Sports Clutch
Nismo Timing Belt
Nismo Intercooler Piping Set
Nismo Steering Rack Bush Set
Nismo Leather Gear Knob
Worth every cent, the gear is just superb :)
Read the first part of your post and thought the second part haha.
Well if Nismo makes a better umbrella than Alfa Romeo, I think I'll go for it...
Hmmm, but not rubber boots Kristian lol
Is there a more comprehensive catalogue than ^^^ ?
I'm surprised at how many ppl here have such sizeable lists!!!
Yeah, there's alot of ppl with empty walllets after looking throught that catalogue
Better add mine,
Nismo short shift kit
nismo radiator cap
nismo cold air intake
nismo oil cap
nismo oil cooler
nismo n1 vents
nismo brake master cylinder
nismo injectors
nismo clutch master cylinder
nismo suspension link components (various - not complete set-up though)
nismo gearbox mounts
nismo engine mounts
nismo fuel pump
and soon to have nismo mfd v2
Probarly a few more that i've missed...
Edited by wedge_r34gtr
Slightly off topic but how to get...
I can get these easily if you need it.
For my ER34
I have S-tune suspension (Willing to Sell)
Speed meter
S-Tune front and rear strut tower bars
S-Tune front and rear stabilizers
Coppermix Twinplate clutch.
S-tune rear tower bar for R32 (Willing to sell)
Side markers
Probably a few things I forgot to mention.
After oil and radiator cap I'll be complete.
Easy to source if there is stock !!
http://shop.nissan.c...duct/detail/515
More here and I can help with purchase but would advise not to buy clothing without trying on first as clothing sizes are for mighty midgets.
http://shop.nissan.c...itemCategory/50
http://shop.nissan.c...itemCategory/51
http://shop.nissan.c...itemCategory/52
http://shop.nissan.c...itemCategory/61
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
