Can anyone tell me if the Nismo oil cooler has a thermostat? [mention=137648]baicai[/mention] do you have one fitted to yours? I'm wondering if there is any issue with over cooling the oil in normal driving situations.
Nismo oil cooler does not have a thermostat, no issue with over cooling, only issue is you have to warm up the car for at least 5 mins before driving.
  • Like 1
What happens if you just start it and drive it? Takes to long to come up to temperate you think?
I am not a big fan of letting cars warm up by having them sit there and idle. I also can not be stuffed with it either. If i cant just start it up and drive it then id rather buy a hks unit with the thermostat and an extra 2 rows on the oil cooler itself.
Any cooler regardless of brand that doesn't have a heat exchanger like the stock one has the potential to overcool the oil if it doesn't have a thermostat. Some people just cover the cooler in Winter. On the other hand any car can be driven away from cold (I never idle cars for any length of time if I can help it) so long as you don't cane them before they get up to optimum operating temperature. Driving them is the quickest way to achieve this.
  • Like 2
Would it be a waste to use oil cooler for a street car? I can imagine it being really useful in the track as you're doing wot most times... doh...
Yep, not required for Street use. I even have mine covered at the track unless it's a hot day.
On 09/03/2017 at 11:37 AM, Anfanee said:
Thought i had posted here but it appears not.... the Headrest on the interior has since been fixed as has the horn button been straightened haha, was a quick snap when instaling. Still restoring the foot rest.
IMG_20161125_1950473.thumb.jpg.af91a48005db5664669f7aa2184baa16.jpg1481531512845867067855.thumb.jpg.714c4564757a223cae19968ff997dbc9.jpgIMG_20161125_1949145.thumb.jpg.91fb13b939ab95afeca4db87d0e46e9b.jpg
Is that also the NISMO pedal kit? Looks like you have installed them over the top of the standard rubber pedals?  I have a set that I am yet to install and am wondering if this is the correct way.
Yep that's them, you drill into the metal for the clutch and brake pedal leave the rubber for the accelerator. Since they were not specifically designed for the 32. Alternatively you could buy a set of 34 pedals to suit.
  • Like 2
Got more pics of the nismo interior and where did you purchase them from
Where you get the nismo interior?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
