  • Replies 221
  • 1 month later...
Are they the actual specs?
I can barely believe that they are worse then the S3
Apple seem to have lost it on this one, even their slogan for the iPhone 5 sucks "The biggest thing to happen to iPhone since iPhone"
WTF
Wasn't considering an iPhone 5 at all, now I wouldnt even have one if I got given one
I love another one of their slogans about the adapter being easier and able to go in either way do Apple users have a hard time with this
Pretty sure that chart is wrong as the S3 has a quad core or was that an LTE version
I also thought it was a 4.7" screen
That's one thing I hear a lot from the iSheep "the OS is easier to use". Seriously, if Android is difficult, you need to go back to a rotary dial phone.
And of course it's going to have a new gen chip, it's 6 months behind it's competitors. What dipshit would release a phone today with a non-latest gen CPU? That's not much of a claim to fame.
"We just released a new phone and lo and behold it's got the latest CPU in it!" Just as Samsung, HTC and Nokia did when they released their phones.
Galaxy S3 would be my pick if I were having to buy a phone myself.
Had a couple of workmates interested in the Galaxy Note recently, as the Ipad is quite frankly too awkwardly sized for a lot of people, the Note seems to be a good medium between a phone and a tablet.
In the past couple weeks I've had a play with my gf's S3, and I have to say I really appreciate the extra screen real estate.
I was waiting to see what Apple did with iPhone 5, and I have to say I'm slightly disappointed.. I really thought they were going to blow me away with some interesting features.
So I had a long hard think today, my mouse was inches away from clicking preorder on an iPhone 5, but the screen was the clincher for me.
So I have a Galaxy S3 now!
Came with a free car kit, bluetooth headset and a 16gb memory card :)
EDIT: I realise that the 4G version comes out next week, but for me it's not really worth the battery life hit, I've never had a problem with current data speeds anyways.
Edited by SoFreshSoClean
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
