I've tried my hardest but i don't have a trailer or a car with a tow hook. Ive also had no luck finding someone i know that has one. The renting path is also not going to work just becuase of how early I need to leave.
So, what happens if something happens to my car and i can't drive it back up to melbourne? Is there an sau club trailer or can anyone recommend a towing company as a last case scenario?
  • Replies 280
Posted Images
To the guys looking at the RS3's.
I got my set for tad over $880 deliverd from tirereack.com. 255/40/17
Couldnt fond them for less than 1100 locally......maybe there is somewhere but thats the best i could do.
They do feel very soft. But they only just made it on the car so havent actually driven on them yet.
Ive had KU36 and RSR's so it will be interesting to see how they compare.
Fingers crossed for some good weather. Good being cold, windy and cloudy....but no rain!!
Cheers,
Dave
Hi Dave,
Will be good to see what you think of them.
What times have you done on KUs / RSRs and what tracks?
Also what car?
Will be good to get a comparison from another user of the KU / RSR.
Hey Femmo,
Its a 33 GTST.
Its had some changes as time has gone on so hard to directly compare.
The RSR's where about 1-2 seconds quicker around winton than the KU36's but they go off after 1 lap!
Maybe its the weight of the car but i never did a warm up....just cruised around for the out lap and then did one timed lap. Although this was during the warmer months.
Looking at my times i get slower after that first timed lap, and you can feel the under steer getting out of control.
I think my best is a 1:41.X on KU's and a 1:40 dead on RSR's.
To be honest i only ran the KU36's for one track day as i didnt like them at all. They were progressive but also went off really fast.
But they where cheap so i suppose its a compromise.
Looking forward to the RS3's. Ive also got more rubber on the front this time so again will be hard to compare directly.
Cheers,
Dave
Car came back with 260 at the treads. Not bad considering it's a tiny 21U housing.
Gah, have to wait 4 days though. 4 painful days!
damn i'm lagging behind
oh well next 18 months is just for shits and giggles anyhow
I would have liked a little more up top, but I suppose that is the limit of the small housing. The larger OP6 housing maybe an option down the track, but WILL require larger rear tyres for sure.
Maybe WTAC 2013 with 280-290rwkw and 285 rears.
I'm up for a garage and in group 2.
no red bus for Katie to keep warm in this time!
I think you can only fit 2 cars.
Do you have to call and book in advance like sandown?
You can call and book.
They only fit 2 cars.
Dave I saw your car in at Tyrepower yesterday getting the O3G's fitted. Much excitement.
Changed the rear tie rods last night....fark it's the bloody HICAS ball joint that has movement, FU Nissan!
The pain the follows removing that SOB with be heavy on the beers.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
