I'll just be over here with my shitbox that currently runs a Nistune and my new engine which will just be a Haltech because that's what my tuner uses.
Had no issues with the old plug and play in the 34, but wasn't exactly doing anything wild with it.
The I/O expander and WB1 boxes all just sat out of way underthe dash, never gave it any thought.
Come to think of it, in all the forums and groups I'm in, only SAU seems to hate Haltech, but I that might be more that I'm in all the pleb groups and not ballers ones lol
well, if your preference is to have to buy all the hardware, whether you use the features or not, Haltech have that now too: https://www.haltech.com/product/ht-195000-nexus-r5-vcu/
And they've done some smart product development lately with the new CAN dashes and button setups
But I reckon horses for courses. Almost every car doesn't use more than the basic ECU features so just use whatever your tuner prefers in your budget. I've got Link in the stagea, Haltech in the GTR, Uprev in the Titan and no ECU at all in the patrol :p, they all do what they need to.
  • Like 3
1 hour ago, BakemonoRicer said:
R32-25t, and pay mega dollars for all the software for motec for one car! Emtron has all the nasa in the one box no software add ons needed. It’s a one stop shop ECU
I thought you were a don!!! a don wouldn’t care about the money a MoTeC costs they’d just spec everything into it and hand them a blank cheque
  • Haha 1
Haltech Platinum Pro, sure it might need all these boxes but it's solid
Haltech Elite Series, no need for a bunch of boxes - also coming soon canbus keypad integration
Cars forgetting tunes? more like tuners clicking on the wrong file and uploading an empty tune.
I've tuned probably more cars than all of you guys put together have tuned, so I speak from experience.
Only excuse for forgetting tunes are the old Adaptronic Selects, I literally had to carry a laptop in the car because on the odd day it would just corrupt itself and add in random values into the crank prime field (known bug).
  • Like 2
Oh yeah, and even though people have Emtron and their tuners use Emtron, I'll be surprised if many even use the fuel modelling. Most still tune in VE because of time/customer's budget.
dropped by insight tonight the car is up and running. It literally is off it’s head, volume is akin to a MIG fighter jet It is the best sounding SR I’ve ever heard, my whole body was shaken from what sounds like a JUDD V8 w/ 320 degree cams. It’s on the dyno tomorrow Scott is going to wind it up his confidence in my physics has gained traction. It’s a special head that’s for sure, one of one
I'm quite fond of you Johnny but I just can't support haltech...shall I post the evidence of you losing your I/O mappings , of course you only spoke about that before haltech formed an alliance with you....
I have alllllllll the evidence LOL #pwned.
i think the removal of the squish pads really adds to the aggression of the sound....
i mean, we are talking soundwaves here and my soundwaves operate from a perfect hemisphere......yep, you got it, no squish pads to disrupt the exhaust gas catapulating into the manifolds. JUN really was onto something back in the 90's....
  • Haha 3
Is the head so special it will hold the bottom end together?
Hope you don’t run out of fuel
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
