59 minutes ago, r32-25t said:
Will the drag strip be open by October?
New track should be finished late Sept early Oct.
I'm looking forward to thtowing the Bogan Cruise Ship down the strip.
Maaaaad skids.
To do list:
Drag radials
High stall
  • Haha 1
5 hours ago, BakemonoRicer said:
Please, if you have any doubts let’s line up player
I’m yet to see any videos of your car light it up, come step to the plate ; )
Ring me when you have trapped 140mph+
For starters, you don't have a 9 second GT-R, nor do you have a dyno sheet....lol
4 hours ago, mlr said:
SAU should run a drag day again.
Lets all go
Put me down for any race 4 real in October as a definite.
I think it should be an SAU roll racing day, the reality is it's much more gentle on the car....than the typical SAU circuit day.
With our vehicles becoming collectible anyone belting them on a track is out of their mind tbh.
  • Like 1
Well I'm stoked to see the car out and about being used, well done.
Glad it didn't blow a box and as you said roll racing is more gentle, being mechanically sympathetic will help, good fluid etc etc it all helps. I've always liked the saying, the candle the burns twice as bright lasts half as long so while it's great it didn't fail, it has done barely any k's under load and down this way my experience has been they fail under track conditions just because it's harder and the loads are sustained for longer.
It will fail at some point, everything mechanical does, and it won't be a surprise or a big deal because it's simply out of spec and we are all constantly pushing shit out of spec then replacing those weak links, get as much enjoyment out of it as you can until that point I reckon.
How are you finding the power delivery and general driving experience vs the GT-R? I've always found that everything feels a bit more raw in a Silvia, GT-R puts down and utilises power so differently - I think that's where the comments come from GTR people saying you need at least 400 or 500kw or what ever power to make a GT-R fun, because they are deceptively good at harnessing greater power levels.
Edited by ActionDan
Sounds fair, although it seems that everyone cheats at roll racing, getting on well before the line in some cases.
I suppose it is better than hitting it down the local off ramp or main road.
Sign me up
Meanwhile.... you don't have to "beat on" a car at the drags to have fun, limiter launches are not required to get a good representative time and trap.
Whilst the Nissans are becoming collectable, and worth some coin, they are not made of glass.
Get out there, I want to smoke some Nisans in my Bogan Cruise Ship.
  • Like 1
Sign me up
And the worst ones for jumping are the people in the really fast car or in super cars (lambo, Porsche etc)
Pff, the ones out of their minds are the ones parking their S15 up in a Carcoon in a shed somewhere and pretending it is a Sandman. I kind of loath the direction our cars are going in, because it is the opposite of what made them popular in the first place. In 10 years time, track days are going to consist of a field of VW Polos and Hyundai I30's, because 95% of people with a 90's performance car will be too scared to use it. Those 5% that will still be out there - you're the real MVP's.
  • Like 3
2 hours ago, acsplit said:
I have seen this a few times now, do you not get penalized for jumping?
Otherwise I guess it is the potato olympics
Definitely the potato Olympics
  • Haha 1
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
